Results 1 to 6 of 6
Thread: VS idle
    VS SS
    Jul 2009
    Default VS idle
    Ok I have a vs ss 5lt manual.
    Now on start up the idle goes a bit over 1k revs then drops right down to around 700-800.
    Thats cold idle and also hot idle..
    But sometimes when its idling in the morning or at a set of lights it will sit at around 700-800 but then dip down to about 400ish for a few seconds then go back up to around 700-800 revs.
    not really sure how ti go about to fix the problem, because surely seeing it idle at around 800 then just dip down to around 400ish revs for a few seconds then go back up is not normal?..
    I'm pretty sure its been doing it for sooo long but never really took any notice but thought I should suss it out now!
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    VS SS
    Jul 2009
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    Throttle Position Sensor just screws to the throttle body. But I really don't see what the problem is. Unless it's causing grief I wouldn't worry about it.
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    VS long bed ute
    Nov 2008
    I started mine vs v6 today and on starting it make a sound like "pewch" or soft mini backfire, then it started to idle inconsistantly at traffic lights etc, but otherwise drove as normal on freeway at 100km. I have been slightly grazing speed bumps recently, could it be something do with exhaust due to minor bottoming out? THe care is not driven hard and no dogey fuel has gone into it that I know of.
    Aug 2004
    Quote Originally Posted by Vs_ss_gmtank View Post
    is it hard to change over.
    Easy to change but you need to take off the throttle body to do it properly and make sure you don't lose any of the bits.
  1. ss ute idle?
    By vyjess in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2009, 07:30 AM
  2. HELP! Vt won't idle
    By !VT! in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-03-2009, 02:08 PM
  3. 91 VN Bad Idle
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-04-2007, 10:26 PM
  4. VP S2 Idle
    By raffie87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2005, 08:25 AM
  5. Very low idle on VN V6
    By HsvMan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2004, 05:56 PM
