Results 1 to 12 of 12
Thread: Auto sump pan stuck on help please
    VR-S series II
    Jul 2009
    Darwin
    Question Auto sump pan stuck on help please
    Hi all ive pulled out my VR 4HDD auto and cant get sump pan off its like its glued on. Is there any special way of getting this off i just dont want to wreck the pan or the bottom of the box. Can any one help as i need to service fix seals and put back in thanx.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    maybe just the gasket sticking to it give it a knock with a hammer
    VR-S series II
    Jul 2009
    Darwin
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you sure you undid all the bolts LOL normally the weight of the oil and the pan it will just drop down by itself
    VR-S series II
    Jul 2009
    Darwin
    Post
    All the bolts are out its fully stuck on tried hammer, tried a screw driver i just dont want to be to rough that it wrecks the pan or the box
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the pan itself is pretty solid shes thick stainless.there should be a TAB on the side of the pan if i remember right to use to lever it off i only just did one a few weekends ago but i forget LOL
    VR-S series II
    Jul 2009
    Darwin
    Post
    Theres two tabs at the bell housing end how and what do i lever it off with
    в∞ѕтεכ √&
    Jul 2008
    NZ
    whatever you can screwdriver etc.or just put a screw driver on the lip of the pan and knock it down off the trans you will have a new gasket in the kit so no need to worry about the gasket hammer and screwdriver is your freind ive never seen one stuck like yours before they normally drop before you get the last bolt even very loose
    VR-S series II
    Jul 2009
    Darwin
    Post
    Ive never heared of it being this hard to get off. im gonna give it a try in the morning its like they glued it on. will it damage the bottom of the box if i jam a srcrewdriver in or will it be fine.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you dont want any big garks in the alloy but try to get between the pan and the gasket not the gasket and trans
    в∞ѕтεכ √&
    Jul 2008
    NZ
    and try to avoid turning it upside down all the shit in the pan will go into everywhere inside the box
    VR-S series II
    Jul 2009
    Darwin
    Post
    Ill try that cheers heaps for all your help hopefully it comes off.
  1. V6 VS Auto stuck in 1-2
    By Cursed CX8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2008, 08:40 PM
  2. auto stuck in third
    By SS49 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2006, 07:06 PM
  3. Removing stuck sump plug.
    By Uber_Matt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2006, 09:14 AM
  4. Dropping auto sump with extractors
    By lazza44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2006, 03:09 PM
  5. removing VL 6cyl auto trans sump
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-11-2005, 10:51 PM
