Results 1 to 15 of 15
Thread: Vs v6 Power Steering Pump Rebuild
    Jul 2004
    Default Vs v6 Power Steering Pump Rebuild
    I have sighted the oil leak and its pissing out the rear of the pump . I read a fair bit on this forum about this subject .
    I haven't done a seal replacement before .Is the shaft seal easy to do ????. Or dont worry about it ???
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Jul 2004
    Quote Originally Posted by greenacc View Post
    the easiest way is to buy a reco pump and change it over.
    I hear what your saying but I dont mind getting my hands dirty . Just haven't tackled one before and mainly worried if I need a press to replace the shaft seal.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    if it's leaking from the rear it's just a 'O' ring. fairly simple to replace
    Body by Holden, Soul by Brock
    the Legend will live forever
    VS Exec
    Jan 2007
    Adelaide (South)
    I just replaced all the seals on my pump, I invented some new swear words in the process.
    I had to do the whole thing as mine was leaking from the shaft.
    Getting the little spring clip off the shaft end is the biggest pain in the arse and then removing the old shaft seal, its stuck in there pretty good. Just tapped the new seal in with a hammer.
    Jul 2004
    Quote Originally Posted by Kingo View Post
    So your saying once I remove the Snap ring called that in the gregorys the shaft is free to be removed. ???
    VS Exec
    Jan 2007
    Adelaide (South)
    Quote Originally Posted by pieces View Post
    Yup, its the only thing keeping the shaft in. But it is a pain to get off, if you had the right tool it would be easy. I ended up using a drafting compass to open the ring and pry it out with a screwdriver.
    I would be very interested to know the proper way to remove it.
    Jul 2004
    Thanks for that Kingo and all the others
    There are circlip plies inners and outers . If the clip has holes in the end I can use those .
    Apr 2006
    Auckland NZ
    sorry mate, it's not a circlip unfortunatly. it's just a wire ring that fits in a groove around the shaft, nothing as fancy as a circlip
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Haha yes that little ring is a pain in the ass! Mine got slightly bent after I got angry with it. But just squashed it back into shape and all was forgiven.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    I lost the ring on the last pump I was doing, it went FATOING!!!!!!!! I through the lot in the scrap metal bin after that, anger does such wonderful things.
    VS Exec
    Jan 2007
    Adelaide (South)
    Quote Originally Posted by azzfox View Post
    Yes, I got a little angry when doing the seals, the high pressure hose wouldn't come off so i ended up cutting it and then with the pump out of the car and in the vice i still couldn't remove the high pressure hose and ended up swinging a hammer wildly at the pump a few times in anger. hit the valve thingy that the line screws into and busted up the thread... plus side was the hose came out.. but i needed to replace the valve thingy as the thread inside was looking a little square
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Nothing like a few "love taps" with a hammer! I was expecting the hose to be a hassle but managed with an open end spanner . Must have been taken off before. The outlet/valve fitting on the other hand wasnt so simple. I broke a shifter in the process, before taking it to a mates place and found a 1" socket, long breaker bar and decent vice does the job easily.
    My (ex)Ride
  15. #15
    Jul 2004
    Thanks every one I just replaced the large o ring all is well now .
  1. Power Steering Pump Rebuild
    By vnvkuserabuser in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2011, 10:26 PM
  2. Replies: 1
    Last Post: 09-11-2008, 09:18 AM
  3. Power Steering Pump Rebuild
    By millencolin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-09-2006, 06:02 PM
  4. Power Steering Pump Rebuild
    By fitykemp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-12-2005, 10:19 AM
  5. Power Steering Pump Rebuild
    By Sacaficial anode in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2005, 03:24 PM
