Results 1 to 3 of 3
Thread: code 24 vehicle speed sensor
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    Default code 24 vehicle speed sensor
    hey does anyone know if this error code 24 vehicle speed sensor would stop the gearbox from engaging 1st 2nd 3rd 4th but allow reverse....
    car reverses fine revs in neautral...
    but when in any drive geas 1 - 4 she just revs...nothing more
    its a vr v6 berlina
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    should still get some drive third gear and reverse is the backup setup for the electronic auto and should still be able to select 2nd as well with the stick
    May 2006
    Perth, Western Aust
    i can move the selector through all the gears that part is fine... but it wont sorta well clunk into gear... its as if its in neutral all through the drive gears 1 -4
    reverse clunks in and works fine..
    the auto hasnt been slipping or anything it was a sudden went to take off from the lights and nothing it just revs....
    the only error that came up was 24
  1. Code 72 - Vehicle Speed Sensor (VSS) and Code 73 - Pressure Control Solenoid Current
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 04:39 PM
  2. Vehicle Speed Sensor
    By JoeNess in forum Electrical Wiring / Questions
    Last Post: 11-05-2008, 09:25 PM
  3. VSS(vehicle speed sensor)how to fix on a VP V8,fault code 24
    By goldvnaero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2006, 09:41 PM
  4. Vehicle Speed Sensor
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-06-2006, 11:45 PM
  5. Code 72 Vehicle speed sensor
    By Notorious in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2006, 01:26 PM
