I got some new spark plug leads today (top gun 8.0mm), and i got given the supercharged ones, i put them on my car and it runs fine, only thing is the heat shields of my old leads wont fit onto these new leads, and cylinder 1,3,5 leads are slightly longer.
Is it fine to use these leads?
Thanks, Jonathan
The only difference in the leads between NA and SC V6 is in the lengths with the SC needing slightly longer length No 1's as the position of the coils is different between the 2 engines.
Don't worry about the heat sheilds as the factory shields don't fit most after market leads and shouldn't be a problem without them.
Col.
