Results 1 to 10 of 10
Thread: central locking
    brooksy Guest
    Default central locking
    my vs passenger door wont lock or unlock with or without the key what could it be :
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Actually my VS doesn't even have a keyhole in the passenger door! But if you mean that the door will not lock when it should then I'd be removing the trim and make sure that the lock solenoid is free to move and not gummed or jammed up.
    Holden Captiva (Work Demo)
    Feb 2005
    my rear passenger door doesnt respond to the key either, im guessing needs a new solenoid, havent pulled the trim off to have a look, cant be bothered really.
    Some people say less talk more action, i say more torque less traction.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I found one of my solenoids were jamming and sprayed the unit with heaps of WD40 - instant fix. It becomes a REAL problem when you think you have locked the car but one door is still UNLOCKED.
    VR Calais
    Jun 2005
    might seem stupid but if u cant lock it by hand either check that the orange tab hasnt come out a bit as it will stop the lock from going down if it isnt all the way in
    Aggro_VE's Avatar
    Aggro_VE is offline The Overseer
    A lazy VE
    May 2005
    Lake Macquarie
    My rear door on my old VS did the same thing, turned out to be the acutator was shagged!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Ash81x - that ain't a stupid suggestion - my drivers door sticks every now and then and I just checked the orange tab and found it was fouling slightly. Thanks.
    VR Calais
    Jun 2005
    Quote Originally Posted by hako
    no problems its only a small thing thats hard to notice
    VS Executive Wagon
    Jan 2011
    Kempsey
    I just tried to convert my Level 2 VS V6 to Level 3 dash but had a bit of trouble so put L2 wiring back in and L2 dash and went to lock the car and only drivers door and tailgate lock and unlock the 2 back doors and pass. door just stay unlocked or if i push them down they stay down any idea what i have done? Allan.
    ss Thunder crewman
    Aug 2009
    Re: passenger door wont unlock i,d say it would be the motor atuator in the door as it is a common problem in the commodores
    ive got a 95 vs wrecking if you need some good ones
  1. central locking?
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2007, 10:49 PM
  2. VR central locking
    By fiendclub63 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2006, 10:34 PM
  3. central locking
    By stewart in forum Electrical Wiring / Questions
    Last Post: 30-10-2005, 02:23 PM
  4. Central Locking
    By Tekka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2005, 02:18 PM
  5. Central Locking
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2005, 07:27 PM
