Results 1 to 3 of 3
Thread: uneven pad wear
    vr berlina
    Aug 2008
    Default uneven pad wear
    wife complained about a funny noise under car.......checked and found passenger side rear brake pads all worn out. The rotors and pads are new all round. Any thoughts about why one wheel has worn like this? I replaced the hand brake shoes at the same time too. Am thinking maybe the slides are stuck? The outer pad is all gone and the inner has minimal left on it. The drivers side pads are still fine...plenty left.
    Any thoughts?
    regards,
    sneezy1
    vs acclaim wagon
    Aug 2005
    Did you ever find a cause as i have the exact same problem on my vs wagon?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    With both pads worn on one wheel it would suggest the slides are stuck and/or the piston is badly corroded and not retracting when the brake pedal is released - this can happen in cars which don't have their fluid changed every few years. But first thing I'd try is free the slides up.
  1. VZ SV6 - Power Feels Uneven When Foot to Floor...
    By mattsv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-03-2011, 02:17 PM
  2. uneven heights
    By VTPREDATOR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-12-2008, 08:02 PM
  3. Sudden vibrations + engine uneven, help!
    By Stressball in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2008, 08:10 PM
  4. Uneven rear tyre wear
    By Scooter79 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-03-2008, 10:19 PM
  5. IRS and the uneven tyre wear
    By commod8 in forum General
    Last Post: 25-02-2006, 07:49 PM
