Results 1 to 9 of 9
Thread: Engine Stalling Below Half Tank of Fuel
    VS S2 Station Wagon
    Jul 2009
    Default Engine Stalling Below Half Tank of Fuel
    I have a 1997 VS S2 Station Wagon. When the fuel tank gets to just below half as indicated on the gauge when I go around a right hand corner or a sustained right sweeping bend like a large roundabout the engine stalls. As soon as the car is straight it will restart immediately. Also if I park the right hand wheels on a high kerb the car will not start. I tried to remove the fuel sensor to inspect it but couldn't get it out through the hole in the fuel tank. Any sugestions welcome?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Never seen it but i heard about it here before. The return line dumps fuel back over the fuel pump into the swirl pot it sits in, if it is disconnected in the tank of busted whateva... then this is a classic symptom of it. It also maybe the walls of the swirl pot have broken away too, in which case new tank is needed.
    Reaper
    VS Acclaim S2
    Feb 2009
    Hackham West
    I had thise as well, but mine its was once it was under a quarter. been told to adjust the fuel lines as to where they pick up n such but it all sounds like too much of a hassel
    GMHCalais is offline [TUKN20Z]
    VY SII 5.7 Calais, VS SS SII HSV Enhanced
    Jul 2009
    adelaide yo
    Quote Originally Posted by SHIFT3D View Post
    have also had this happen to me on a main road during peak traffic. car didnt restart therefore steering was impossible and the brakes were stiff as ****.. pretty scary. lucky i could turn the steering wheel enuf to getinto a small streetand slowly ease on the handbrake lolllllll.
    must have sometyhing to do with the fuel lines. am getting mine checked next service..
    Slammed 5.7 VY calais II tuckin G8 20'z
    VS S2 Station Wagon
    Jul 2009
    What is a swirl pot and is it part of the tank. Can you get to it by pulling out the pickup and sender unit.
    I know nothing about the fuel system, as you might have guessed!
    32pseye is offline 32pseye
    Vr aclaim
    Apr 2007
    warrnambool
    the swirl pot or commonly called anti splash tank keeps fuel right where the fuel pump picks up. thus to prevnt car stalling when fuel is low and moving side to side when cornering
    in a vs wagon it is located (looking at the front of tank) in the lefthand rear corner. not to sure if you can pull it out with fuel sender out, probably easier to replace tank
    VS Acclaim
    Jan 2006
    Almost every holden i have ever owned or been in does the cutting out thing around right handers when pushing hard. It is very frustrating at times and would love to know why!!! (my old kingswood would do it no matter how much fuel in tank but my VS seems to only do it with less in the tank, but is still super annoying!!)
    VS S2 Station Wagon
    Jul 2009
    Thanks to all I have just found an older thread that discusses my problem and has some fixes mostly replacing everything including the fuel tank. So I think I might just put up with it for a while!
    VY Executive
    Jul 2009
    Newcastle
    maybe u jus got shit in ur fuel tank floating round and wen it gets halfway it tries to get sucked up and blocks the fuel line. Same thing happened to my mates hilux.. he swapped his tank and it was sweet.
  1. Strange fuel related, half tank, right corner problem.
    By adomatt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2009, 07:51 PM
  2. VR SS Sedan Engine Light Half Lit
    By mectec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2009, 11:27 PM
  3. fuel tank gurgles when engine switched off
    By greenacc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2008, 10:56 AM
  4. scored half a engine :)
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2006, 06:08 PM
  5. Can only fill my fuel tank about half??..
    By LXRB-30 in forum General
    Last Post: 05-06-2006, 04:34 PM
