Results 1 to 16 of 16
Thread: Question about Statesman/Caprice Clock
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Default Question about Statesman/Caprice Clock
    Could someone who owns a Statesman or Caprice tell me if the analog clock in the dash is backlit or not? I want to see if I can get one and install it in my car somewhere. Thanks.
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    also let us know if it hooks up to a constant 12v source or not? thanks also
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by seraphic06 View Post
    Yeah they are backlit, connected to the parking lights i beleive,
    skater: Yes they would have constant power
    Power is measured in DECIBEL
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    yeah i been thinking of grafting a clock on for ages, gonna be a tough job though
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Okay, I bought a clock off eBay for the princely sum of $6.50. I cut off the three tabs that hold it on to back of the dash pad.
    I decided not to try and make it fit into the dash facia and went for a spot on the drivers door instead.
    It uses three wires in order to function properly - one for constant 12 volts, one for illumination and one for the earth. I ran the cables behind the side air vent and through the grommet that is used for the door loom. The door trim needs to be removed to do this. I earthed one wire to the body. The illumination wire runs to the brown/white wire in the dash loom and the constant 12 volt wire is grafted in to the constant running to the head unit. It is held in place with some strong double sided tape and back of it is just covered in some cloth. At some stage I will change it to a grey coloured covering that is more suited to my interior colour scheme.
    After some thought I decided that the clock looked a bit bland so I went and bought some 2.5mm balsa wood, measured the clock and went about making a new face for it. After measuring, cutting, sanding, staining and varnishing I came up with something that looks a lot more appealing and blends in with my other woodgrain trims.
    Attached Thumbnails Attached Thumbnails Question about Statesman/Caprice Clock-dsc_8805.jpg   Question about Statesman/Caprice Clock-dsc_8806.jpg
    Bagged vs caprice sII
    Sep 2007
    Newcastle
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Have you thought about using a VQ roof clock? It would require you to cut your roof lining, but its as simple as buying a VQ roof lining for $18, cutting it straight, and merging it with your wagon lining.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    should have got a vr clock. they have a holden lion in the middle
    but looks good. thats two things vs's were missing. a clock and cup holders.
    Jun 2005
    Quote Originally Posted by Haydz View Post
    vs caprice has both of those covered. sort of
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Quote Originally Posted by STEALTHY™ View Post
    No, I must admit that I haven't.
    Actually I did bid on one of those but there were two other jokers and they got into a bidding war which I wanted no part of.
    STEALTHY™'s Avatar
    Jan 2005
    Can see it on the far right (which is the front of the roof lining)
    cheers sexy
    simmons001's Avatar
    simmons001 is offline I like VS Caprices
    WH Grange/VS Caprice S1 5.0
    Jul 2005
  15. #15
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    Quote Originally Posted by simmons001 View Post
    Cup holders in a VS caprice? my S1 sure doesn't. Something i don't know?
    series 2 and 3 had them in the centre console lid.
    and stealthy. i effing love the look of vq roof clocks. if only they continued that through the commodore range. we would be on time
  16. #16
    STEALTHY™'s Avatar
    Jan 2005
    I love them too, thats why i have 2 roof linings and 3 clocks, so i can have one in each car (plus a spare considering i bought the clocks off ebay, ones bound to be a dud)
    I was gonna go with the SV3800 clock i had, but they have red digits, the roof clocks have green digits. I like green
    cheers sexy
  1. WH Statesman clock wires ?
    By Fletch_QLD in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2010, 09:07 PM
  2. VR STATESMAN CAPRICE..5.0 ( of course)
    By sedate looking in forum VR - VS
    Last Post: 01-03-2009, 03:54 PM
  3. WTB - wh statesman dash clock
    By lumina01 in forum Swap / Wanted to Buy / Trade
    Last Post: 03-02-2008, 12:01 AM
  4. VQ Statesman Roof Clock
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2007, 09:42 PM
  5. turn clock back. vr statesman
    By gold statesman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2005, 06:32 PM
