Results 1 to 5 of 5
Thread: Vacuum Ball
    VS Commodore Omega
    Apr 2005
    Default Vacuum Ball
    Just a really quick couple of questions -
    What is a Vacuum Ball, do all VS V6's have one and is it important?
    Thanks
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    it stores vacuam so the air vents dont change position when you give it heaps of throttle from the lack of inlet vacuam when the throttle is open
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    lol, you will find it under your front left gaurd, near the windscreen washer tank.
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    *** This is a post which I did on another forum which relates to my 500hp VL Turbo. The vacuum ball does exactly the same on the VS model ***
    It is a vacuum reserve. It is used to store air to help keep air con vents on the setting that you choose such as face. feet or windscreen etc. Reason why its there is because when the car is close to zero vacuum under acceleration or actually in boost (ie no vacuum in the manifold), it uses the stored air in this vacuum ball to keep the vents on the current setting.
    I have removed the vacuum ball from my vehicle. The side affects are that if im accelerating and the vacuum is close to zero or in the positive (boost), my vent changes back to default which I think is maybe the feet setting. Its a small thing to worry about for me as the extra room made way for 2 trans coolers in the place where the vacuum ball once resided.
    Yes I still run air con and yes if I have the vents set to face and fan blowing strong, when I accelerate at any level above granny spec, the air reduces and in heavy acceleration it stops coming out of face vents and goes to feet or windscreen until I back off and I reduce the engine manifold back into the vacuum reading.
    Its up to you whether you want it there or not (you can even relocate it to another location without too much fuss if you like). I can put up with it gone as normally if its hot enough to use the air con, then its normally not the wisest thing to be consistently heavily accelerating, although even with mild acceleration, the flow of air is nearly non existent until I back off and drive under steady throttle.
    VS Acclaim
    Jan 2006
    Always wondered what that black ball was for!!
  1. ball joint?
    By TWOJZ in forum General
    Last Post: 25-06-2008, 09:11 PM
  2. vs ball joints
    By sik888 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2008, 04:13 PM
  3. little ball under the air box??
    By defa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2007, 08:55 PM
  4. New ball joints
    By AL-X in forum Holden Commodore How-To's
    Last Post: 27-11-2005, 07:27 AM
  5. Vaccum Ball
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2005, 03:41 PM
