Results 1 to 3 of 3
Thread: Code 47 - CAS
    VS S2 Berlina
    Jan 2009
    Question Code 47 - CAS
    Hey guys just a quick question,
    when checking for error codes i get the 12 (normal) coming up three times then code 47 three times and back to 12 again. I cant work out what the code is telling me as the car doesn't miss a beat and starts fine, but does like drinking fuel occasionallyl.
    Does anyone know what its tellin me?
    VS II Ute V6 1996
    Jan 2009
    Lake Macquarie NSW
    Hey Mate, I had this code come up back in April, after my car stalled on me, and then later on would not start straight away. Check out this thread.
    Code 46 and 47
    From what I know, the ECU stores codes until it is reset, so your error code may be way old. I replaced my CAS because I had problems starting the car. It is all good now.
    It seems like a common problem.
    Hope this helps.
    VS S2 Berlina
    Jan 2009
    Thanks. Ill try doin a reset and see if it comes back
  1. Code 72 - Vehicle Speed Sensor (VSS) and Code 73 - Pressure Control Solenoid Current
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 04:39 PM
  2. code 68
    By maco_butterfly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2008, 05:23 PM
  3. code 31
    By vs_commodore_s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2008, 09:42 PM
  4. code 31
    By bucksta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2006, 07:23 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
