when i was driving home today, after my blinker turned off.. it kept ticking (the sound) in the dash..
then i saw a small amount of smoke coming from the cluster and could smell something burning.
i turned off the car for a min and the problem went away.
any ideas what could have happened???
shorted wire sumwhere , the flasher unit died etc .
or you let the smoke out of the flasher unit which is never a good thing .
are the blinkers working again ?
When was the last time you checked your indicator fluid ?
open up the fuse panel and look for something burnt out.
you might need a performance flasher relay if you turn corners often.
blinkers seem to be working fine now... i dont know what could have happened... its very weird
