Results 1 to 6 of 6
Thread: shudder around 80 k's
    vr executive
    Jul 2009
    Default shudder around 80 k's
    need help 1994 vr have a shudder around 80 - 100 k's stops when i back off now i have had tran out and replaced theTorque Converter with a one out of a vn is there any difference / had it all out trying to track another problem thats why it was replaced never done it before.
    94 VR Calais V8
    Aug 2007
    Sydney, NSW
    Quote Originally Posted by stumpy03 View Post
    Don't know if this helps. I assume the shudder appears or is felt quite suddenly at around 80Kmh ?? If so its probably the torque converter locking the input and output shaft.
    Whow, now I'm going back to 1991 ! I had a V8 VN calais that started doing exactly what you describe after about 19,000km. It would occur at about 80kmH when the torque converter went into lock mode. Backing off eliminated the shudder like yours does.
    Holden replaced the auto under warranty, and it did exactly the same thing. Then after a very stern discussion Holden replaced it a second time and all was sweet up to the time I sold it at 160,000km.
    Good luck
    97 VS BT1 Commodore
    Apr 2009
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the TCC clutch in the torque converter is most likely worn out and its slipping too much when it goes to lock and iff you squeze the power on when they slip they shudder
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Acclaim VS SII
    Jan 2009
    Good to a Good Year tires service (or your personal favourite wheel dealer) and ask them to do a wheel balance. If you've put new tires on or adjusted springs etc, your car will probably need a wheel balance .
  1. Shudder
    By hazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-03-2009, 06:06 AM
  2. Shudder
    By jonny6guns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2008, 09:11 PM
  3. car shudder
    By kunifa in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-05-2007, 09:30 PM
  4. VT shudder
    By MrE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2007, 05:19 PM
  5. Shudder on Take off
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2006, 09:32 AM
