Results 1 to 6 of 6
Thread: how to replace rear suspension [ live axle ]
    vx berlina
    Aug 2005
    gladstone
    Exclamation how to replace rear suspension [ live axle ]
    hi guys it should b straight forward i guess but can anyone explain exactly whats involved with changing the rear springs and shockies on a vs v6 sedan i dont have spring compressors can i get away with big g clamps ? there only soft old stanard coils with 250 thousand km on em lol cheers muz
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Unbolt the shocks at the bottom and the springs will fall out. Then open the boot and unbolt the shocks at the top if youre changing them. No need for spring compressors.
    Make sure you have the car supported by the chassis and not the axle housing for obvious reasons.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VY Executive
    Jul 2009
    Newcastle
    Hey bud.. Is vs irs or not? im not sure. id get a set of spring clamps but, i seen a set in supercheap for bout $20 the other day.
    If its irs. Its real easy. This is wat i did.
    1. wen the cars jacked up.. jack the wheel arm up...
    2. undo the handbreak and all that u can see that is preventing the arm from dropping.
    3. while u have the arm jacked right up attach the spring clamp and tighten right up (has to b real fn tight)
    4. drop the jack holding the the arm up.
    5. pull spring out (sounds easy enough huh, i think ull find its a slut to get out!)
    6. put new spring in
    7. jack arm back up
    8. Put all the bolts bak in that u took out to let the arm drop.
    9. drop same jack holdin up the arm
    10. put wheel back on. Alls done!
    If its irs and u live near newi and u need a hand pm me.
    good luck dude.
    94 vr wagon & 94 vr sedan
    Nov 2008
    rushworth vic
    I just done the rears on my wagon. azzfox is spot on with his description don,t forget the torque settings for the arms. upper arms 60-75 nm lower arms 95-110 nm shocky lower mount nut 26-29 nm thats by the gregorys book
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i had to tear the diff out of my live axle vs not long ago (dont ask) the max ellery manual i had said to torque up the diff arm bolts while the suspension has weight on it. i dunno if it makes any difference but all i did was jack up the diff until the car was about to lift off the stands and torqued em up. its an easy job you'll have it done in no time
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    How to change rear shocks (wagon)
    this might be some help
    Reaper
  1. cutting bumpstops rear live axle
    By axemurderer101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2009, 11:22 PM
  2. FS: Munroe gt gas rear shocks VS live axle
    By rawnrg in forum Parts And Other Items For Sale
    Last Post: 11-05-2008, 11:04 AM
  3. IRS VP rear springs into Live Axle VN
    By Steery in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2008, 02:09 PM
  4. oil leak from rear live axle
    By Black VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2008, 07:38 PM
  5. wtb standard rear fe2 live axle springs
    By bMcgrath84 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-01-2008, 09:18 PM
