Results 1 to 5 of 5
Thread: Exhaust Change (will it fit?)
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Default Exhaust Change (will it fit?)
    Hi guys,
    Just wondering if anyone has attempted before I do...
    I want to swap a VR commodore exhaust with a VR series 2 commodore exhaust.
    First question:
    Are they the same size etc? I presume so.
    Second question:
    Do you guys know if it will be possible to change it on a ramp?
    The only bolts are just behind the cat (we're only changing behind the cat), and I have some doubts about getting them in and out because of the bends over the axle.
    Cheers,
    OzJD
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    as long as both exhausts are Live or both IRS then yes, should be just a straigh swap. Should be easy enough to do on ramps.
    is the replacement exhaust larger or the same size?
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    There should be two bolts just in front of the diff too, attaching the front and rear sections if it is a factory system. If it is an aftermarket sports system, then it should have a clamp join there.
    And yeas, as ephect said, they are a straight swap. By the sounds of it, it's a live axle as you mentioned the bends over the diff.
    Visit my Facebook page
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    I know one of them is a custom 2.5" (I bought it, that's why I wanna transfer it.
    They're both Live Axle : )
    As for one, it has a clamp, and there seems to be a join that has some silicon type crap at the join...
    as for the other, I don't think there is any join (i'll double check when the Mrs gets home (within the hour)
    It just dosnt seem high enough reversed onto ramps
    Current Issue(s)
    N/A
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If you can separate the two parts on the system that you are going to fit then it is very easy to fit. You can get the rear one in by turning it sideways and sliding it in from the rear, then twisting it to the correct position.
  1. Exhaust / Catalytic flanges, Exhaust swapping
    By social in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2009, 11:02 AM
  2. extractors, will it change exhaust sound
    By ragrim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-06-2008, 03:01 PM
  3. Wanted VS V8 exhaust / HSV exhaust / Merge pipe
    By prettyboringbloke in forum Swap / Wanted to Buy / Trade
    Last Post: 21-02-2008, 03:06 PM
  4. Oil Change/filter change interval on VTII 6 cyl ?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2006, 04:26 PM
  5. Want to change my exhaust
    By lowwagon_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2005, 02:10 PM
