I'm considering getting my engine reconditioned but not sure what to look at
I've been told i can get extra power by adding larger pistons etc
what else can be changed to add extra power
and what price would i be looking at to do so?
thanks
Instead of getting a recon and trying to scrounge power out of the 3.8 did you consider going v8? Just a suggestion.
You could stroke your 3.8 to 4.2 while your at it? you looking at some $$ there though.
Most people just do cam, roller rockers and forced induction.
Please do not print this sweet post. Save our forests. Save our World.
unless you wanna do up the v6 then i would just look at getting a second hand low k motor for cheaps. If you still wanna go down the rebuild path then im sure a stroker kit wont break the budget, find out how much extra to get the heads ported as opposed to just re-machining them back to factory spec and whack a bigger cam in with some new rockers. Its gonna cost you a bit, but while your doing a rebuild its goin to be the most efficient time to do it.
