Results 1 to 10 of 10
Thread: VS cruise control switch (where to get one)
    VS SS
    Mar 2009
    Default VS cruise control switch (where to get one)
    Hi all, my cruise control is not engaging, (VS Calais), i have a feeling its the switch on the brake pedal, just want to know where it is i can get one and approximate cost? Do places like Repco, Bursons etc etc sell them? I have replacecd the indicator/cruise stalk so i know its not that. Thanks in advance.
  2. Default
    have you actually tried adjusting the switch first?
    this is for vn/vp, don't see why the switch would be different for vs though. maybe it is - but you can at least give this a shot for now until someone else replies.
    link to VN thread
    Quote Originally Posted by zai View Post
    I am not sutpid
    VS SS
    Mar 2009
    thanks levymetal for posting that, yes i have tried to adjust it but still no good......
    VS Berlina 3.8
    Dec 2008
    Have you tried checking your brake lights? Criuse control will not engage if your brake bulbs are blown.
    VS SS
    Mar 2009
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Check across the contacts of the extra switch with the grey connector at rest with a meter if it shows a circuit its working fine....ive never seen one not working as they are pretty basic.The cruise circuit actually uses both brake switches to ensure it always releases the cruise control when you jump on the pedal.As a test you could short the extra switch out with a bit of wire and go for a drive and see if it works and on the off and near impossible chance be ready to switch it off at the stalk switch if both switches dont turn cruise off when you jump on the pedal.
    Most likely cause of cruise not working is a broken wire in the stalk if the brake switch is adjust properly.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VS SS
    Mar 2009
    so can i get a cruise switch from somewhere like repco, supercheap etc etc ???
    VS Series II
    Nov 2007
    Newcastle
    I have seen them floating about on ebay, along with full kits. might be worth a look if your not in a hurry for one.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    When I tried to buy one the only place that could supply one was the local Holden mob - they said they had to order it in and would cost $59 - ended up going to a wrecker and got one for $10. The bloke at the wrecker said they rarely sold one as they never seem to fail. Mine was needed as I was retrofitting genuine cruise.
    VS SS
    Mar 2009
    looking at the panel for the relays / fuses under the dash, there isnt a relay for the cruise, and doesnt look like any wires have been chopped, so looks all factory, does this seem ok? Seems a little strange to me......
  1. Cruise control release switch
    By vtclubby in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2008, 04:17 PM
  2. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  3. FS: Cruise Control Switch
    By VX_BERLINA02 in forum Parts And Other Items For Sale
    Last Post: 29-07-2006, 05:57 PM
  4. Cruise control switch block
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2006, 01:22 AM
  5. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
