Results 1 to 6 of 6
Thread: new struts r in but cant get bottom link pin nut back on ??
    vx berlina
    Aug 2005
    gladstone
    Exclamation new struts r in but cant get bottom link pin nut back on ??
    hi guys yayy finally got my struts on my vs v6 sedan done but for the life of me i cannot get the bottom link pin nut on where the link pin joins the end of the sway bar i just dont have the room to get thAT nut on the thread any ideas what i have done wrong guys ? thyanks muz
    2005 VZ SV6 A5 & 1997 VS II A4
    Sep 2006
    SE Qld
    If you have your car on jacks, with the suspension 'hanging', try putting the weight on the wheels. Put the car on ramps or lower it onto blocks under the wheels so you can still work under it. Sway bar, links etc sit at awkward angles when the suspension is hanging.
    sycvs is offline commo for life
    vs executive
    Jul 2009
    phillip island
    i just used siscer jack with a spanner standing up on the top of it and jacked the sway bar up and put nut on
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    do the top one up fully then if you turn the strut left or right you will see the link bar move on a angle and it will give you enough space to start the nut on.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    have you dropped the sway bar, by the sounds of it you havnt? Undo the 2 clamps holding it up so you can let it hang and manouver it easy.
    Reaper
    VY Berlina V6 / R31 Skyline
    Dec 2008
    i used an axe handle to lever my sway bar up to get the bottom link pin nut on, also try turning the wheels different ways.
  1. vp bottom control arm
    By markovr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-12-2008, 12:59 PM
  2. 5L Bottom End
    By Sedat in forum Parts And Other Items For Sale
    Last Post: 29-10-2008, 01:53 PM
  3. turbo v6 , l67 bottom end or rebuilt ecotech bottom end?
    By petezor in forum V6 Development And Modification
    Last Post: 25-01-2007, 12:16 AM
  4. bottom end for 5.7L how much??
    By QWK-11E in forum V8 Development and Modification
    Last Post: 25-10-2006, 12:59 PM
  5. Wanted 355 Bottom end
    By VL2Di4 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-05-2006, 10:12 PM
