Results 1 to 5 of 5
Thread: Man conversion-cruise control, will the auto cruise control work on manual conversion
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default Man conversion-cruise control, will the auto cruise control work on manual conversion
    If i convert my auto '93 berlina wagon to manual from vr ute (with no cruise) of the same year will my cruise control be affected?
    And if so how do you fix it?
    sycvs is offline commo for life
    vs executive
    Jul 2009
    phillip island
    it will work on the man aslong as it is conected up the same way as on the auto my mats done it in his 94 vr and probs yet and it been 3 years
    VN S1
    Jan 2008
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    my cruise aint working since converting to manual,the dash lights for it dont work and im wondering if thats the problem
    WTB:VR/S HSV 250km/h speedo cluster
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    yes it does work, I know mine in my vr is an auto cruise setup(someone did it before i bought it) as it has no clutch switch + theres some wiring i can see thats not factory on the brake switch.
    It is very benificial to not have the clutch cut out switch as it lets you go down gears when hitting a steep hill without having to reset the cruise. Its not really a saftey issue either, if theres a a car stopped ahead i generally hit the brake anyway which cuts it out.
    Just be weary of 5th gear on rough roads if it jumps out of gear, it will hit the rev limiter pretty quick.
    Reaper
  1. does cruise control work with manual ecu in vs s2
    By clubby_you in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2009, 10:52 PM
  2. Brake lights and cruise control don't work
    By savage1987 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-10-2008, 09:48 AM
  3. cruise control in a manual vr
    By tangooly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2008, 10:42 PM
  4. Cruise Control Wont Work
    By porkkhunt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2007, 08:33 PM
  5. Help! Cruise control for VT 5.0L manual
    By wilko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-09-2006, 08:16 PM
