Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Does my fuel economy sound about right?
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Default Does my fuel economy sound about right?
    Hey guys,
    Just finished a tank in my car... I push the counter at the petrol station so this is exactly right.
    I got 268km's out of a VS V6, CAI, Extractors/2.5 exhaust. It ran on premium/V-power whatever it is can't member which one.
    Does this sound about right or not... If it doesn't what could be the prob?? O2 sensors?
    Thanks In advance.
    Ben
    There is no such thing as stupid questions, Only stupid people.
    HAIGHIE is offline HAIGHIE
    VX Executive S2
    Jul 2009
    wollongong, NSW, AUS
    hey
    if ur driving it hard around town and that, thats probly about the amount of kms you'd get. if thats freeway these a problem somewhere u should be getting around 500 - 600 ish
    this is going off the 70lt tank
    VQ stato 90'
    Jan 2009
    Somewhere on the Great Ocean Road :)
    thats about what im getting, and its definatly not good
    im replacing my 02 sensors very soon
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by tristanjp View Post
    O2 sensors should be fine. They either work or they dont.
    Mine has about the same setup minus the extractors plus 200kg extra weight.
    Im getting around 850kms to a tank of Vpower on the highway.
    I'd suggest you clean your MAF sensor, change the plugs, leads, oil, oil filter, injectors, plenom (general service)
    Also depends on the thickness of oil you use. And the condition of your transmission if an auto. Aswell as tyre preasure ect...
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Car is serviced like every 3000kms, As its free for me. MAF is clean, did it when i did the intake. Leads, Plugs have done about 2000kms. Oil is 2 fuel tanks old as is oil filter. Injectors? Don't know about them maybe i'll check them. I cleaned the Plenum of the carbon deposits when I did the CAI, as I cleaned the TB. Oil is 15w 30 Castrol Syntec <-I think.. Trans had a 3 grand rebuild with TCI Internal parts, all solonoids etc. were replaced as well as the all the internal electronics.... Also has a Foam tune?
    Any other suggestions.
    Ben
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Yeah run some injector cleaner through it.
    Your biggest problem here is your running Vpower and getting shit economy. If you ran normal unleaded you would have even worse economy.
    Also try using mobile8000 if you can find it,
    After I ran a few tanks of BP98 with HP booster (98% meth) the economy got alot better. Mainly because i think the methenol was cleaning the injectors right out.
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    I used to run 104 Octane boost stuff... Coz I get it for free... still have a few bottles left might stick some in.
    Still I think there is something going on or I have a fuel gremlin who drinks it alll, either one...lol
    Ben
    car
    Jul 2006
    greensy, melb
    at one point i was using alot of fuel and i couldnt work out why cos it was the same scenario as you, everything new/replaced fairly recent then one day was going over everything with the car running and found out the fuel hose connecting to the fuel rail was loose and was leaking fuel from there.
    go over all you fuel lines and make sure they are tight and as said also do injectors and it really cant hurt to get a new o2 sensor, i would just so i knew it was new for piece of mind
    "A life lived in fear is a life half lived"
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    I'm under the bonnet a fair bit, I think I would smell fuel leaking but I'll check anyways. Now you've said that i have to, like you said its peice of mind thing... Might just rplace the O2's and run some proper Injector clean see how she pulls up...
    Ben
    '97 VSII Executive V6 Auto
    Aug 2009
    sydney
    Quote Originally Posted by TrikkBen View Post
    Hey guys,
    Thanks In advance.
    Ben
    assuming it's a 59L tank like mine, you should be getting around TWICE that! whats more, thats using 91RON ULP
    u may be thrashing it, maybe the o2 sensors..... maybe the sparkplugs need cleaning... check ur airsystem...
    VQ stato 90'
    Jan 2009
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Quote Originally Posted by Ozzie View Post
    This isn't right. Just because the sensors aren't logging an error code, doesn't mean they are accurate. It is well established that all sorts of things (silicone, coolant, lead, soot) can foul the sensor, leading to inaccurate readings. There are loads of posts on this topic.
    I was getting around 10L/100km with oxygen sensors that hadn't logged an error code (done ~160000). When I changed them I saw an immediate 10-15% improvement in fuel economy.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    hey mate that doesnt sound too good, i just serviced mine and i got 440k's this week, thats flogging it around canberra so city driving.
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    I no sucks so bad... costs me like 60 bux a week....
  15. #15
    5 speed VR's Avatar
    5 speed VR is offline Green Machine
    Vr V6 Exc 5 spd
    Apr 2006
    Sunny Coast QLD
    Im currently getting like 8.5lts/100km, just a manual VR with a Delcowizzid and thats driving pretty hard round town aswell as highway travel running on V-power.
    When i grow up... i want to be young again
  16. #16
    padrickz88's Avatar
    padrickz88 is online now Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Change your o2 sensor/s and your coolant temp sender (the one to the ecu)...
    Usually i would say spark plugs, oil, leads etc etc but you said your car is serviced regularly so they couldn't be the issue.
  17. #17
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Why would the Coolant Temp sender bother the fuel economy? does the ecu change fuel ratios depending on coolant temp?
    Ben
  18. #18
    5 speed VR's Avatar
    Vr V6 Exc 5 spd
    Apr 2006
    Sunny Coast QLD
    If the temp sensor is sending the wrong info to the ECU, i.e it will run rich as it might think its constantly cold.
  19. #19
    VR Calais SeriesII
    Nov 2008
    Quote Originally Posted by 5 speed VR View Post
    Yeah if the ECU thinks the engine is colder it'll throw in more fuel to bring it to operating temp like how the choke works. anyway that's what i'm hoping happened to me since i just replace mine in my VR like 4 hours ago getting like 14.7L/100Km hurts the bank.
  20. #20
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    ahh yeh, now I get it.. I've had a Snap-On analyser on the car and it showed nothing, might put it back on and check again.
  21. #21
    Dec 2008
    $60 a week? Thats not so bad mate, but for the k's your doing it is. i spend between $65 - $75 a week but i generally do around 500k's
  22. #22
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Yeh man I don't mind paying that but for 250ks its shit as...
  23. #23
    Dec 2008
    yeah for sure. i hope it gets better mate, i was in your boat a little while ago but a cleaned out MAF sensor, and a full service saw me getting 440k's to a tank. and really good injector cleaner on a tank of premium too
  24. #24
    mrhotdog is offline What Would Jesus Do?.....
    2003 VY S1 Acclaim
    Nov 2007
    Adelaide, South Australia
    i get anywhere between 250 and 350 out of a tank, but it only cost me $25 to fill up
    Originally posted by TVR-161
    " they dont have probs caz da cop chip is better den da normal chip yo, it makes shiz work"
  25. #25
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Woah. Ben, dude 268 k's out of a tank of V-Power Petrol. I get that much out of my LPG tank man. My petrol tank lasts a good 450-500k's around the city.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
  1. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  2. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2010, 04:29 PM
  3. Bad fuel economy, strong fuel smell?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 08:43 PM
  4. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-05-2007, 09:39 AM
  5. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-05-2007, 09:01 AM
