Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: What Am I?
    VS Series II
    Nov 2007
    Newcastle
    Default What Am I?
    I am located behind the pulley for the belt.
    And also behind the motor for the power steering.
    I connect to the cooling system, and run into the heater tap.
    I am the bottom of the two that connect to the heater tap from the motor.
    I am leaking underneath where I join the motor. How can I fix myself? And how much am I worth.
    Also - where is the manifold air sensor located? is it the same as the meter?
    Thanks
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    You sound like a water pump. Usually you do not fix yourself, but Im assure if you file the appropriate formers it will get back to the manager of the car in which you work and a change request for a mechanic to fix you will be made. To be honest mate you sound about as valuable as a packet of chips if you are bleeding green blood. If you were not in need of some serious stitches then I would value you around the $150 mark I think.
    This is the first water pump I have even seen able to post on JC, might be worth sticking yourself on Ebay mate.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VS Berlina 3.8
    Dec 2008
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    you sound like the thermostat bypass pipe?
    or did I miss something? you run behind a pulley and behind the powersteering and into the heater tap?
    does it leak near the thermostat? or does it leak from behind a pulley over on the passenger side of the engine?
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Get a pic of where she leaking from man, alot easier to point where it's leaking with a quick paint arrow, then we be able to tell you what u need to get.
    ________________________________________
    VS Series II
    Nov 2007
    Newcastle
    There are bolts holding me on. The one closest to a rubber pipe which leads to the heater tap, holds an earth wire for an o2 sensor or something like that. The other is located close to the water pump behind its pulley.
    Dannyboy - "you run behind a pulley and behind the powersteering and into the heater tap?" thats the one. Its just a bit below the pulley tho. It appears seperate to the water pump.
    - It leaks where it curves and goes into the motor. From front on, just to the left of centre, and right of the pulley.
    Will get a pick tommorow if that description is no better.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    dont think its the water pump from your description, sounds like the idler arm assembly. it connects to the heater tap and its the part that the alternator bolts to.
    you cost about 100, cant remember exact as this was a few years back, its fun to change but nothing a little time will fix.
    VS Series II
    Nov 2007
    Newcastle
    yeah. the alternator is a fair bit higher.
    If i wanted to find a price online, would i just search idler arm or something to do with the cooling system?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    search for tensioner arm assembly, tensioner assembly or tensioner arm, its more pulley side than cooling but both lol if that makes sense.
    as long as you comfirm its the part i have described, thats what it is
    VS Series II
    Nov 2007
    Newcastle
    VS Series II
    Nov 2007
    Newcastle
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    sorry mate, i was talking about the part just above that. i cant recall that part off the top of my head.
    looks like there are only a few bolts holding that on. you may have to remove the tensioner arm to get to it, i think!
    VS Series II
    Nov 2007
    Newcastle
    thats cool mate, I just wanted to be sure.
    Ive been searching far and wide for the name of this part. I don't own a manual, so I had a stickybeek at supercheap, and it had nothing about it in there.
    I dont really like going to mechanics, because sometimes if you ask them, they sort of take over and think its there job, and I want to see if i can get it cheap, do it myself, and learn a little about things.
    So the name of it comes to mind, please let me know - its rather frusterating
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    In one pic there you have a decent shot of the part number. It it is that metal pipe that its leaking from maybe replace that pipe. It shouldn't cost too much from Holden.
    If its leaking from where the metal pipe connects to the rubber hose it may be a split or perrished hose. Sometimes tightening the clamp may solve the issue.
    Otherwise it may be a gasket that is leaking. Either get a new gasket or use a gasket silicone.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
  15. #15
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
  16. #16
    VS Series II
    Nov 2007
    Newcastle
    a shot in the first pic has the leak sort of showing - that dark spot underneath its join.
    My old man - who is the chief of the car, seems to think i should have a replacement part incase its corroded.
    Im hoping just an o-ring.
  17. #17
    VS Berlina 3.8
    Dec 2008
  18. #18
    hakhawk's Avatar
    Jan 2005
    id rip it off before buying a replacement one, save spending unnecessary money.
    find someone who can get one first, then order/buy if you need it.
  19. #19
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    sorry for stealling your thread but does anyone know what theese hoses next to the engine do?
  20. #20
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Quote Originally Posted by fuzzy2308 View Post
    I think you'll find they are your heater hoses.
  21. #21
    Sep 2008
    Quote Originally Posted by aceventura View Post
    They are your heater hoses.
    sweet do i need them? can i plug them up coz i broke the plastic conector thingie from sittin on my engine
  22. #22
    hakhawk's Avatar
    Jan 2005
    replace it, theyre not expensive
  23. #23
    VS Series II
    Nov 2007
    Newcastle
    Lol, your right mate. Its what forums are for.
    Those hoses connect to your heater tap, then from there go inside your car.
  24. #24
    VS Series II
    Nov 2007
    Newcastle
    I got mine for 28.00 on ebay if you want a replacement - or otherwise u can remove one, and loop the single one back upto where you pulled the first.
  25. #25
    VS Series II
    Nov 2007
    Newcastle
    I've decided I'm going to take a gamble tommorow or the next day and pull off the weird part and suss it out.
    I've got pretty bad luck with these things, so it will probably need a replacement - but hell least it will be off and i can walk it around with me lol
