Results 1 to 6 of 6
Thread: Vs commodore, how do i get too the globe ib my break lights
    VS executive
    Jun 2009
    Default Vs commodore, how do i get too the globe ib my break lights
    sounds like a dumb question but i just had a look and theres carpet over where back of the lights are and after peeling that back i cant see any way to get too the light... i just need to change a globe,,how the hell do i get too it
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Go into your boot, behind the tail light lenses INSIDE the boot, pull the carpet away and unscrew the bits holding the globes in. I have never done it on my VS, but i assume it's the same for VR VS as it is for VN VP.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Undo the 3 nuts off the threads that are sticking out under the carpet, then pull the light assy. out.
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    OMG what a thread man.
    Dont need to pull the light assy out, just unclip the plugs on the light
    Grab the plug where the wires run outta, twist it to the left 1/4 turn, it will then slide out, push in the bulb n twist out it comes, put in newbie.
    Find what light has blown, then find the plug for it, right behind where the light is, or should be.
    ________________________________________
    VS executive
    Jun 2009
    ahh ok so just twist the plug with the wires and it wil have the globe attached?
    sounds easier than it looks.
    VX S2 S-Pac
    Oct 2005
    ummm with the VS u have to take the assembly out as there is only a rubber grommet which all the wiring runs thru...follow Andrew426's advice, the other guys obviously are only referring to VN/VP
    VR through to VX wrecking in WA, must get rid of these!
    http://forums.justcommodores.com.au/...res-vr-vx.html
  1. VS commodore t-bar globe...
    By VsAcclaim1312 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2009, 09:30 PM
  2. break lights too bright
    By System in forum Electrical Wiring / Questions
    Last Post: 17-11-2008, 09:45 PM
  3. Power Button Globe & A/C Globe Replacement
    By mourati in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2008, 11:39 PM
  4. brake lights not functioning - fuse and globe OK
    By familyguy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-02-2008, 08:57 PM
  5. wat size globe 4 interior lights @ back
    By slwbt1 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-10-2005, 11:23 PM
