Results 1 to 2 of 2
Thread: roller rockers
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    Default roller rockers
    I have sifted few a many forums but cant find what i want to know. I am new to the technical engine side of cars and im trying to get an understanding for roller rockers as its the next thing i want to do to my car. What is this difference between switching to a 5/16rocker and a 3/8 rocker. and what is the difference between 1.7 & 1.8? I have read information on the Yella Terra site but im just wanting confirmation on my thoughts.
    Your advice is appreciated
    Dave
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    not 100% sure on the 5/16 n 3/8, guessing its bolt size.. but its the 1.7:1 and 1.8:1 is what you want.
    its how much it'll lift/drop the valve when it opens. i believe 1.8:1 is the max for the buick, but dont know for sure. The more lift, the more air its letting into the cylinder, hence more go, is the basics
    What have Yella Terra listed for your engine? All you need to ask is you want the ratio (1.7:1 or 1.8:1) for your VR, hand the cash over, install them and thats about it
  1. roller rockers help.
    By vn calais manual in forum V6 Development And Modification
    Last Post: 29-04-2009, 07:21 AM
  2. roller rockers
    By Macka21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-01-2009, 10:22 PM
  3. Roller Rockers for my VR
    By haniotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2008, 08:42 PM
  4. 1.97 Roller Rockers with cam?
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2007, 12:19 PM
