Results 1 to 19 of 19
Thread: 1995 VS Acclaim - Trans + Smoke?
    FinalCause's Avatar
    FinalCause is offline Whole Collect
    VS Acclaim
    Jul 2009
    Two Wells, SA
    Question 1995 VS Acclaim - Trans + Smoke?
    Hey, pretty new to the forum but everyone seems to have a decent knowledge when it comes to things going wrong.
    I bought a 1995 VS Acclaim last friday, $2400 with no rego. So far i have had to do the following:
    • Replace front rotors
      Replace front calipers (bleeders wouldn't budge)
      Repair scissor arm on driver window
      Replace driver door handle
      Replace transmission seal (where the dipstick pipe goes into the gearbox)
      Still need to attach LHS boot hinge (take the parcel shelf out etc)
      Still need to replace heater tap assembly and hoses.
    And possibly 100 other things...
    Im noticing when im driving that if the car rapidly climbs in revs, it feels as if the trans is catching, wobbling...all that kinda stuff (even after replacing the seal and topping up trans fluid)
    Also, when the engine idles, it seems as if a smoke is coming from the exhaust, havent noticed a colour, kinda clear but smells of petrol.
    Does anyone have any tips or suggestions as to what these things maybe and any possible solutions? i dont want to replace the trans $$$$$$ but if i have do, it has to be done.
    This is my first V6, love the car, not loving the trouble. haha.
    Thanks!
    Cause.
    FinalCause's Avatar
    VS Acclaim
    Jul 2009
    Two Wells, SA
    bump, really need some help, i drive 40km to work...80km round trip per day, id hate to get stuck half way haha
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you haven't already changed the engine oil and filter, air filter, fuel filter yet then I'd do that now. Then do a codes check for any logged fault codes (see how-to section)
    Re the trans, if the oil is brown the trans may be near the end of its life...maybe a can of trand fix will prolong it.
    Does the car lose coolant?
    Vr Executive 3.8
    Dec 2008
    If the car is shooting up in revs but going no where fast then your transmission is most probably slipping.
    FinalCause's Avatar
    VS Acclaim
    Jul 2009
    Two Wells, SA
    thanks for the replys guys,
    hako: ye, i think the oil might have been brown...im getting a mate round tomorrow morning so we can spend some time looking at it. i didn't even think to check for error codes, once i wrap my head around the how-to i'll do that haha
    Chris: its not so much shooting up in revs as it feels like it gets stuck periodically then its fine...
    FinalCause's Avatar
    VS Acclaim
    Jul 2009
    Two Wells, SA
    also, i clicked the link for code explaination...its gives me two options...VR (1993-1995) and VS (1996-1998)
    i have a 1995 VS V6...so i guess its falls into both categories...which link shud i follow?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    if ur car is a VR (buick engine) then click VR if its a VS (ecotec) as your ride states, then click VS
    FinalCause's Avatar
    VS Acclaim
    Jul 2009
    Two Wells, SA
    haha word.
    yea, i checked the codes, all it gave me was the code 12 and then code 23...
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    and code 23 is... post up
    FinalCause's Avatar
    VS Acclaim
    Jul 2009
    Two Wells, SA
    Mass Air Temp Sensor (MAT) high voltage
    Not entirely sure what it means, i know it starts a bit rough but thats no biggie, and the temp gauge gets to about 3/4 on a prolonged idle before the fan kicks in.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    the temp at 3/4's is fine, most VS's report this and is normal.
    the MAT or IAT is located on the side of the air box, u'll see a plug & loom connected to the air box. this could be stuffed or this code could be logged prior. Remove the + lead from the battery and leave it for 10mins. connect it back up, go a couple of days and see if it logs that same code again. If it does replace the sensor with a new one preferably or secondhand one from a wreckers.
    i would do the oil, oil filter, air filter and fuel filter as hako suggested sooner rather than later.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    after you remove the lead turn your lights on or try starting the car to drain all the circuits. Failing to do this can fail to delete the codes.
    FinalCause's Avatar
    VS Acclaim
    Jul 2009
    Two Wells, SA
    ok great cheers for the advice guys, ive gone and removed the lead, turned the light switch on for a bit and replaced the lead...i'll see how we go in a few days.
    Any suggestions on the state of the trans? i'm hesitant to take the car any higher than 3500rpm...only because it feels weird every now and then, almost as if the gear is catching on occasion...not sure
    thanks again
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    first check the codes again to make sure they've cleared
    i would be getting your auto reco'd sooner than later by the sounds. has it been getting worse lately or just all of a sudden?
  15. #15
    FinalCause's Avatar
    VS Acclaim
    Jul 2009
    Two Wells, SA
    not sure, i only bought the car on friday haha
    i drove alright when i bought it, then i noticed a leak and discovered it was the trans seal at the dipstick pipe into the box. Got a replacement from holden.
    I was told that the car hadnt been driven in over a year. In the owners he must have written a reminder for the water pump to be replaced at 221,000 and this was on 07 date. Today, the car has done 228,000
  16. #16
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    damn we'll i would firstly change the trans fluid and filter, can be done yourself or and trans joint. at least give it fresh fluid. start it & let it run, let it get to operating temp, then let it cool a little, then change the oil, just dont get burnt if doing it urself.
    if its been sitting there for over a year, most parts wont have been lubricated and on startup it can take a while for the oil to coat everything. even though u've driven it home. me personnally would take it for a nice cruise steady speed, will get fluids flowing in all places might dislodge any gunk.
    Change your o2 sensors which would fix the petrol smell from the exhaust, if its using extra fuel the O2's arent doing their job.
    sounds like it's gonna cost you a little bit more to get her back in shape
  17. #17
    FinalCause's Avatar
    VS Acclaim
    Jul 2009
    Two Wells, SA
    yea i know ay, well i only paid $2400 for it and have managed to get decent parts from wreckers at low cost, so i think if i get this thing driving real nice im coming off pretty gud haha.
    Any idea on the cost of those sensors? i assume id have to get them through GMH?
    thanks for all ya help mate
  18. #18
    greenacc's Avatar
    VE Berlina
    Jul 2008
    you can get aftermaket O2 sensors, just check they are decent brand such as Delphi.
    Good idea to change the tranny fluid as ephect said. Its a cheap job at about $60 DIY- service kit with gasket and filter is about $30 from repco, plus fluid another $30, and might even cure your slippage.
  19. #19
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    yea holden have them for i think $70-90 per sensor or ebay for about $60 you want delco or adeco (another member should confirm), your VS should have 2, check your exhaust pipes, both left and right sides, u'll see em thru the bay down low next to the trans. If you can get to one of the plugs, check to see if you have a 2wire or 4wire O2, you will need this when you purchase them.
    lol sometimes you can get something good for cheap, and somethings cheap can be seldom good, i hope you have the former not that latter!
    EDIT: Delphi not adeco thanks greenacc
  1. 1995 VS Commodore Acclaim
    By Billo55 in forum Vehicles For Sale
    Last Post: 27-10-2008, 09:45 AM
  2. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  3. 1995 Vs Ute
    By pandacav in forum Vehicles For Sale
    Last Post: 31-10-2006, 07:50 PM
  4. VS Acclaim 1995 problems
    By paulandloz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2006, 03:14 PM
  5. VS Acclaim 1995 for $5.000
    By simmo 76 in forum Parts And Other Items For Sale
    Last Post: 03-03-2006, 09:03 PM
