Results 1 to 23 of 23
Thread: antifreeze or water in your radiator ?
    INSAYN's Avatar
    INSAYN is offline INSAYN
    1993 VR Calais V8
    Aug 2005
    Wanganui NZ
    Default antifreeze or water in your radiator ?
    should i be using antifreeze ? {5L V8 }
    05
    pjdm1980's Avatar
    pjdm1980 is online now The Holden Hunter!
    Feb 2009
    Geelong, Victoria
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    anti freeze or at least anti boil with a anti corrosion protection with distilled water.
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Yes you should. Just go to holden and buy genuine coolant and mix up in the correct ratio as specified on the bottle. Coolant does many jobs like keep engine cool, stop corrosion, resist freezing and boiling. Don't just use water. Genuine is great and not that expensive.
    VT spac super6
    Nov 2008
    Riverton sa
    Quote Originally Posted by HoldenOnn View Post
    It only raises the boiling point slightly doesnt increase cooling efficiency
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    Quote Originally Posted by HARVZ-6 View Post
    When I referred to it as 'keeping engine cool', I was referring to the whole concept of water flowing through the engine and I wasn't saying that having coolant and water as opposed to water alone makes the engine cooler.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    good part of the anti-freeze is the anti-corrosive properties, which when mixed correctly helps stop you engine rotting from the inside out
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    cooling efficiency LOL, thats true, plain water has to best cooling efficiency but see just how long your engine lasts using straight water.
    Use the proper green stuff, there are many good reasons for it.
    Acclaimed VS is offline cruising
    VS Acclaim
    May 2009
    Use coolant I can tell you that after speninding more then I care to metion fixing my car from the ******** who owned it before me not using it.
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    what ever you do, dont mix brands of coolant. Stick to one brand whuch is readily available
    dont worry, il start a ride thread soon.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    no you dont have to use anti freeze, i only used it in my car when went to he snow. It dosnt get cold enough here to warrant anti-freeze.
    Reaper
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    There's no need to use anti freeze unless you live in an extremely cold area. If you need anti boil you have other issues. Just buy a concentrate (green stuff) that has a rust inhibitor. Mix that with tap water and do a flush every now and then.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by maldotcom2 View Post
    Don't be misled by the term anti-freeze. To quote: "I'm sure that you've read or heard somewhere before that water is the best coolant. This is true as far as being able to absorb heat for a given flow rate, water does do that the best. Water also boils at a lower temperature than other coolants and can develop steam pockets easier, so it's not the best coolant in that respect. A water / ethylene glycol mixture (anti-freeze if you like to call it that) will boil at a higher temp and resist steam pockets better than plain water, the downfall is that it has to have a higher flow rate, but that is easy to accomplish" (modern engines that recommend ethylene glycol already have the necessary higher flow rate).
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Don't use normal tap water use distilled water will save you having to pull out your dash when your heater core shits itself.
  15. #15
    Vp series 2
    Jun 2008
    water will allow the inside of your radiator and engine to corrode, is will then flake off and clog your radiator.
    coolant will slow this down a hell of a lot.
    I had a 1967 6 clyinder landrover that always had collant and it was clean inside.
    Christ knows how many times it had been around the clock.
    It was that old the rocker shafts had worn about 1mm
  16. #16
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Quote Originally Posted by centy View Post
    wow theres your proof mate, tap water has to much mineral content and will stain the internals like a toilet cristan or kettle.
  17. #17
    VrWagz1's Avatar
    May 2008
    wollongong
    Of course you must run a rust inhibitor, but the question was should he run anti-freeze, answer is no if he dosnt live where it goes below 0 degrees.
    Reaper
  18. #18
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    question was, anti-freeze or water.. my vote is anti-freeze
  19. #19
    VN Calais
    Jan 2009
    Melbs
    If you have *good* water, ie not crap full of lime then just use that. From NZ im sure the water will be great?
    And for the cost, inhibitor is a no brainer, just get some from kmart or something. Or if you want genuine, look at the genuine bottle, read the genuine ingredients, (% mixes), then go to kmart and get the same as genuine for less price....
  20. #20
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    distilled water $5 for 5 litres, when you spend $25 bucks on coolant why cheap out on the last $5?
  21. #21
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by Da_rooster1980 View Post
    exactly!!
    if u do it properly from the start, u save money down the track, i cant understand some ppl's logic.. its ur engine ur screwing with, treat it well n it will last.
  22. #22
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    If you live in Melbourne, my work has 20 litre drums of distilled water, will cost you about $13+ GST.
    Very handy stuff. I even use it when i mix washer fluid.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
  23. #23
    vr statesman 5.0 + vs exec s2 auto
    Mar 2006
    central coast, nsw
    i recently had our 2 holdens cooling systems flushed by a radiator specialist , he has had his business at the same location for 15 years . he just recommends a product called " FORTRON " cooling system treatment . it is a corrosion inhibitor and water pump lubricant. he reckons that is all the v6`s and v8`s need , unless they are in snow areas. the FORTRON is made in western australia . has anyone else heard of it , or have any comments about it ? ........
  1. Radiator - Bubbles in water.
    By calais_cruzin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2009, 03:47 PM
  2. [SA] wtb - radiator water tank for vn s1
    By Pimpn1 in forum Swap / Wanted to Buy / Trade
    Last Post: 13-01-2009, 12:39 PM
  3. best antifreeze/inhibiter
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2009, 06:02 PM
  4. Losing Water from Radiator?
    By VXdarkmagic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2008, 04:46 PM
  5. Water in oil, Oil in radiator
    By 610 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-04-2005, 07:08 PM
