Results 1 to 9 of 9
Thread: wont start!
    vt s pac
    Sep 2008
    Exclamation wont start!
    Hey just wondering if anybody would know the problem, fitted new rocker covers to the mrs' vr v6 buick, the seals were leaking.
    Now that i try turning it over it turns over a bit then siezes!?!?
    any help would be much appreciated!
    Cheers, Ben
    vt s pac
    Sep 2008
    some1????????
    think its something to do with the timing but dont know how it would be out??
    or how to fix timing issues?
    Vr Executive 3.8
    Dec 2008
    If all you touched were the rocker covers and it was running fine before I don't see why it would have seized, is the battery fully charged?
    vt s pac
    Sep 2008
    yeah the battery is in good order and the electronics seem fine, at first i thought it was just a lead not on the a spark plug properly coz it was rough as guts! it sounds like its gonna wreck the engine if i keep trying to turn it over.
    VR 3.8 1994
    Jul 2008
    check your crank angle sensor, it might of coincedently just gone on its way out
    VN dmg90,VZ ute,DRZ400e
    Jul 2009
    Nth Qld
    vt s pac
    Sep 2008
    na not the ignition leads, i made sure i marked them correctly and double checked them just then 2.
    just checked the crank angle sensor and the plug had a fair bit of oil in it so might try replacing the unit 2moro nite if i get the chance.
    cheers for the help, Ben
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe you've disturbed something ignition related - usually it will be plug leads on the wrong pluds as Bombsky says...or maybe the coil packs have been disturbed. I'd retrace all steps you took when doing the job.
    vt s pac
    Sep 2008
    triple checked the leads and it was a pair going to the wrong plugs. think i was thinking to much bout the whole thing and just made the easy mistake.
    cheers for the input dudes!
  1. wont start
    By byt in forum Electrical Wiring / Questions
    Last Post: 03-12-2009, 08:33 PM
  2. VP V8 Wont Start
    By E_ri_k in forum Electrical Wiring / Questions
    Last Post: 04-03-2009, 03:57 PM
  3. VR wont start
    By Rumbl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2009, 12:35 PM
  4. VN wont start
    By 89berlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-11-2008, 10:34 PM
  5. Help Me, Car wont start!!!
    By Bleaaargh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-01-2006, 05:50 PM
