hi ppl. i just had my vr in for a rwc and one of the things picked was that the srs airbag light doesnt come on. ive checked error codes anf none come up for the srs. is this likely to be a globe failure or is there anything else that can cause the light not to work?...also the car is on dual fuel but it wont even run on petrol. is this a rw item for it to do so in vic. any help much apprecieated.
Sounds like you are having a bad run.
Re the airbag light I'd say a previous owner has cut the wire to the globe or otherwise disabled the globe so as not to show an airbag fault. I'd pull the dash and check for cut wires or a missing bulb. If this is the case you will still probably have a airbag fault - this will need to be removed by Holden or a auto elec who has a Tech2 scanner. Airbag faults are not logged like other faults so you cannot see them.
Cannot help you with the gas/petrol problem.
Good Luck.
Check the globe first
as for the car not starting on petrol it could be a lot of things is the fuel pump running ? and are you getting fuel pressure ?
