Results 1 to 11 of 11
Thread: vs clubsport issue
    vs clubsport
    Aug 2008
    Smile vs clubsport issue
    hey guys im having some issues with my vs clubsport the motors been rebuilt also gearbox and diff its a 5 speed manuel im running a inner active manifold with active top hat with twin throttles i noticed slowing down in 2nd gear at the lights around 15km my car starts to jerk about4 times then its fine its also bad stop n go in traffic doesnt seem to feel torquie as it usetoo be before feels sluggish .. also car seems to hunt on idle like up n down for like 2 times then will drop to 1000rpm and idle perfect sumtimes it will stay on idle at 1500rpm during driving n stop conditions
    wat could this issue be ?? any ideas
    the car hasnt been tuned yet due to running engine in and ive removed pcv vavle and bypassed all vaccums off the throttle bodies and just running
    2x oil breather filters off the rocket covers.
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Get it dyno tuned man, should fix that up. Especially the idle. Unless there is a vacuum leak. Then all vac lines for splits if they are all originals. Mine was doing that weird idle, fixed the split fuel pressure reg vacuum line on the manifold, cleared it up perfectly. Gonna do the MAP sensor line next.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    vs clubsport
    Aug 2008
    im thinking my twin throttles are playing up when i pull the throttle cable back to open the flaps on the throttle bodies 1st throttle opens perfect the second throttle doesnt open 100% how can this be fixed i was told by a mechanic i had the throttle bodies wrong way round for 1 prefomance mechanic told me ??
    shown in the pic the left throttle touches that metal thing on full throttle the other throttle misses it by a finger away from it ??
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Hmmm, not too sure mate, might need to ask someone who knows a bit more about twin throttle set ups. All i can say is, that ain't right. Might play a part in your problem, but might not, i would think that it would be just like having only one TB opening.
    Is your car internally modified or is it just the twin throats?
    vs clubsport
    Aug 2008
    damn ok man i think this is why my car seems to be blowing black smoke also
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    If it's blowing black smoke, it's running rich. Get it dyno tuned for sure dude. Get that air fuel ratio leaned out a bit, then you will get the most from your twin throats and other mods.
    You in Melbourne?
    vs clubsport
    Aug 2008
    *** it bro im gonna piss that off and run a 4 barrel double pumper ontop with a round k&n should do my treat my bros ordering it next week
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Bwahahahaha. that would look pretty sweet. Still, get it dyno tuned though. You won't regret it. Expensive, but worth the cash.
    vs clubsport
    Aug 2008
    yep will do mate just gonna drive it more ive only done 400km i gotta do 1000km
    before it gets dynoed
    ive had a look at this edelbrock universal quad throttles efi 1000cfm il slap that onto the inner active high rise plane manifold with nice filter all under bonnet cant wait
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Ahhh, still running it in! Fair call! Just make sure you get someone decent to cut out the hole in your bonnet for the filter
    vs clubsport
    Aug 2008
    wont need to it will clear it just fine
  1. vs clubsport gearbox issue
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2008, 01:53 PM
  2. 97 clubsport steering issue
    By semio88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 06:29 PM
  3. VS Oil Issue
    By Mecgun in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2008, 09:56 PM
  4. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  5. Here's a new one... (VE Issue)
    By CSP in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-04-2008, 05:33 PM
