got a mate with a VS GTS 215, manual.
his clutch just kicked the bucket...
are the 6 speed clutch issues the same as the 5 speed hydraulics? i.e. are they dual mass? can you convert to solid flywheel?
some advice would be appreciated
thanks
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
can someone move my thread to v8 development and modification section. thanks
pretty sure they are solid flywheel, have a talk to ACS and see what they recommend
Yep, they don't have a DM flywheel, but they're a chevy clutch, so the pricing is still fairly ordinary...
In Exedy, std are $1019, HD are $1159 and cushion button are $1619.
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
Yep, pretty much. Just take the old flywheel out and machine.
Most clutch kits (excluding those for dual mass or flywheel replacements kits) are in the $200-$500 mark. Being such an odd model it's more expensive, and although it's still a 'GMK-' part number, our price list says it's a Chevy clutch, which explains the price... it's not common to any other Commodore...![]()
