Ok so my passenger front window is half way down, and the rocker switch has broken. What wires can I bridge to close it? I've left my wiring diagrams at home so I can only guess at what wire does what.
Do I bridge the yellow (up side of the rocker switch) wire to the orange/yellow (power I assume)?
And yes it is the rocker switch that is gone as it has been on its way out for a while now, and every time you opened the window it was gamble to see if it would close again lol
Anyone? It's raining and the bag around the door is starting to look shite...
from memory, blue and green go to your door so place power to one of those 2.
ok I'll give that I go now...fingers crossed
could always spray a little wd40 into the switch, worked for me, 3 years on and still works fine, I think the contacts can clag up sometimes.
If you're really desperate, rip the door trim off an connect a 12v battery direct to the regulator... Polarity will change which direction the window winds.
