Results 1 to 12 of 12
Thread: Vs Antena
    VE SV6 Commodore Ute
    Aug 2009
    Default Vs Antena
    Hey Guys,
    Ive just got myself a Vs ute and ive noticed that the radio antena stays up. Now im not sure is this ment to stay up or should it go up and down when car starts??
    If so is there anyway to fix this??
    Thanks
    VS Series II
    Nov 2007
    Newcastle
    FinalCause's Avatar
    FinalCause is offline Whole Collect
    VS Acclaim
    Jul 2009
    Two Wells, SA
    my vs came with the aerial clean cut off...probably a tragic car wash accident. im not sure wether or not they go up down automatically. Check the owners manual, it may give u a clearer picture.
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Aug 2009
    well i cant pull it up or push it down so im guessing that the antenna motor is broken??
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    There's a couple of ways to tell if you have an electric antenna.
    1.) You have up/down buttons next to the air con/climate control.
    2.) The top of the antenna itself is black (not silver/chrome).
    3.) Remove the front left splashguard from the wheel well. Is the antenna has a motor, it's electric.
    Aug 2009
    Hmmm i have no up/down buttons
    and the tip is silver
    so im guessing its just a little siff.. Ill try some old WD40 and see how it goes
    thanks
    VS exec
    Jun 2009
    bong from the gong
    Stock stereo or aftermarket.
    If aftermarket does the car have amp ?
    if its aftermarket with a amp, perhaps they have used the blue switching wire to provide the power to the amp.
    I have had cars before with power antennas even with anew one you could still push it down and pull it up but you would hear it turning the cogs etc
    VS Executive
    Aug 2009
    townsville
    i have the same problem.. my antena gets stuck on the second last rung.. do they go all the way down normally?
    VX
    Aug 2009
    Yeah, similarly with my VX when i start it and turn it off i hear the electric motor whiz, but no movement of the antenna. Go figure.
    pjdm1980's Avatar
    pjdm1980 is online now The Holden Hunter!
    Feb 2009
    Geelong, Victoria
    Default Crappy Holden antennas
    Crappy Holden antennas I'm on to my 6th antenna in 5 years (AND I'M NOT REPLACING IT AGAIN) and I'm not replacing it had the same problem on 2 of my old VP's and my old VR!!!!!
    Aug 2009
    Thanks Guys
  1. uhf antena replacement
    By shonky12 in forum The Pub
    Last Post: 27-12-2008, 04:11 PM
  2. Annoying Antena
    By Soud in forum Car Audio
    Last Post: 30-03-2008, 03:03 PM
  3. Annoying antena
    By Soud in forum Electrical Wiring / Questions
    Last Post: 28-03-2008, 03:23 PM
  4. VT antena help
    By danx in forum Electrical Wiring / Questions
    Last Post: 10-07-2006, 06:29 PM
  5. Electronic Antena Noise
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2005, 11:03 PM
Tags for this Thread
