I was wondering if you use a 94vr ecu in a 93vr? do you need to change map sensor if it is possible?
As long as both ECU's are for the same specs ie: V6 / Auto, V6 / Manual you should be Ok.
The map sensor does that need to be changed aswell? when i install the ecu of a 94vr.
Just thought i'd the question.
