Results 1 to 9 of 9
Thread: problem with my VS BT1?
    manual VS 355 BT1
    Jun 2009
    Default problem with my VS BT1?
    hey people i have a 95 VS BT1 factory manual 355 stroker. iv had a problem with it for the last few weeks.
    sometimes it will start an sometimes it wont!!!
    its like it wants to start, but it just wont get that final spark to ignite and run!!
    i have put new leads, new sparrk plugs in it an changed the ignition module < ( spelling )
    if i push start it it will fire an run, then you turn it off an then start it again an it will start!!
    i dont know wat else it could be??? i had it at the machanics for three day an it started
    everytime!!! how typical!!!
    if anyone has any ideas, let me PLEASE!!! that would good
    cheers matt
    VS Berlina 3.8
    Dec 2008
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    VT HSV Senator Signature
    Jul 2009
    Check earthing - very important to make car go.
    Had same problem with mine. The one time it didn't work perfectly for the mechanics, they found it straight away. Rotten earth cabling. battery to body, and body to some other bit under the bonnet.
    manual VS 355 BT1
    Jun 2009
    Quote Originally Posted by BlackVXGTS View Post
    Is this problem when the engine is hot, cold, or both?
    yer either really!!!
    yer might check the earthing then, see how i go!! thanx guys
    manual VS 355 BT1
    Jun 2009
    if i push start it though it will run an then it start fine after that!!! its so annoying!!! then you leave it for a while an then it wont start!!!
    Aug 2004
    Also check the continuity of the power wire that runs from the battery into the engine harness and then to the starter motor, as well as the connector itself.
    manual VS 355 BT1
    Jun 2009
    well i just tried to start it and yep, it wounldn't start!!! so i push started it an it was fine... turned it off then tried to srart it and it wouldn't start!!! hasn't done that before, normaly starts straight away!!!
    its like it not getting any compression when key starting it, wen you push start it it starts really easy.. only need about 10 meters to push it!!!
    i mght try putting a new coil on it an see wat happens... it has to be something to do with the spark so!!! see wat happens!!!
    thanks for your help so far guys
    manual VS 355 BT1
    Jun 2009
    found out wat the problem was!!! a weak spark!!! lucky i brought a new coil!!!
    all good now!!!
    thanks heaps guys for all your help!!
    cheers matt
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. VS Ute PROBLEM!!!!!
    By Leathal11 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2009, 10:31 AM
  3. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  4. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  5. Problem 4 VN SS
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2005, 05:59 PM
