Results 1 to 8 of 8
Thread: do you need gaskets when installing pacemakers?
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Default do you need gaskets when installing pacemakers?
    hey guys.
    going to be installing my pacemakers tomorrow. just not sure if i should get a set of the metal gaskets or is it better to use a gasket goo etc. any help appreciated.
    anyone with experience with a 5 litre especially.
    cheers
    H1GHROLLR's Avatar
    H1GHROLLR is offline CHEMICALLY SUPERCHARGED
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    i use the metal gasket and a thin bead of high temp gasket goo
    {H1GHROLLR} CHEMICALLY SUPERCHARGED A.K.A NITROUS FED R8 CLUBBY and {HYPED UP} TWIN TURBO VX SS DAILY
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    yes. get the gasket, nothing worse than an exhaust leak
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    I'd use the gasket so they seal nicely. As said above, nothing shitter than an exhaust leak.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    Jun 2005
    yes you need the gasket. bursons had mine for $13
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Some say no but I can never get them to seal properly without one.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    thanks for your input reaper.
    got the manifold gaskets for 15 dollars.
    and the ones cat ones for 4 dollars each.
    you dont have to tell me exhaust leaks suck. when i had the stock system on it. rust had set in. and the dodgy metal holden make their exhausts with was crumbling. and sounded horrible.
  1. pacemakers on vn
    By Haydz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2008, 03:26 PM
  2. VN V8 Pacemakers
    By ryan_VL in forum Parts And Other Items For Sale
    Last Post: 15-02-2007, 09:18 PM
  3. Pacemakers
    By roger05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2006, 10:39 PM
  4. new pacemakers
    By cqcfighter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2005, 06:40 PM
