Results 1 to 5 of 5
Thread: Fuel lines....what are they made of, hard to replace?
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Default Fuel lines....what are they made of, hard to replace?
    Hey guys, i have had a few vacuum lines split on me lately due to being the originals, they were extremely brittle and broke easily between my fingers with slight pressure.
    Was wondering, after the dear passing of Nige's VS SS due to the split in the fuel line, what are fuel lines made from? Are they rubber like vac lines?
    How hard are they to replace? I'm in the process of replacing all hoses etc with fresh ones. Already done all the cooling / heater hoses (top and bottom rad hoses) and the fuel pressure reg vac line and just about to do the MAP sensor vac line.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    VS exec
    Jun 2009
    bong from the gong
    they are made of rubber and are made for use with fuels, normal rubber hose will get eaten by the petrol, thou i have used garden hose before as a emergency fix this was before sunday trading and it was replaced on moday morning with the correct type hose
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Go down to autobarn/bursons/supercheap/repco, EFI Fuel hose,
    EFI Fuel hose can deal with transmission fluid & Petrol
    Transmission hose can only deal with Trans Fluid & Not petrol.
    Never get that confused!
    Also EFI Hose you'll need is 5/16 & measure ur lengths.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Sweet cheers Hozy!!!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Also use good quality worm drive clamps on the fuel line to the fuel rail as it is under high pressure - I done my daughter's VT a few days ago and it had those stainless crimp type clamps that eventually loosen - fuel was dripping from the joint.
  1. how hard to replace a auto box
    By plymouth_hemi_69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-05-2009, 07:29 AM
  2. V6 timing chain is 500,000km old. Hard to replace DIY?
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2009, 09:07 PM
  3. VT Brake Lines made of Copper
    By Thumpin in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-03-2006, 11:17 AM
  4. How hard to replace big end?
    By NAY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2005, 11:23 PM
  5. Headlight switch, backing light. Hard to replace?
    By aa23 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2004, 08:25 PM
