Results 1 to 12 of 12
Thread: Blinkers!
    VRoooom!'s Avatar
    VRoooom! is offline Vroooom!
    VR Executive Series One
    Aug 2009
    Default Blinkers!
    driving from A to B next thing my indicators dont wanna work?
    ideas?
    i cant drive to work now
    thanking yoou
    VRooom!
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    And if the fuses are OK change the flasher unit....but first check whether the hazard lights work - if they don't I think it is a problem with the hazard switch that stops the indicators working.
    Good Luck.
    VRoooom!'s Avatar
    Aug 2009
    yeaaah boy.
    fixed it like 2 days ago.
    i didnt realise i had two fuse boxes!
    thanks broski
    krzyvs's Avatar
    krzyvs is offline Stalker
    vs 2 spac/vp exec
    Aug 2007
    newcastle/sydney
    so what was the problem and how did you fix it where is this supposed second fuse box
    I don't fear the fall, I fear the sudden stop
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    well you know for future reference, if electrical circuits go check the fues then relays :P
    VT series 2
    Dec 2009
    Hi all,
    I have the same problem I cant find the second fuse box, i have read is located under steering column?
    all I can see is the engine computer and it looks like it is a sealed unit, any help would be great.
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    ECU is usally in the passanger side.
    The fuse box is located behind a cover that is usually removed by three clips.
    The other one is in the engine bay on the drivers side
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    VT series 2
    Dec 2009
    Now i am confused, engine bay fuse/relay got that, under dash passenger side just seems to be heater etc, under steering columb is a grey box, but looks like it is sealed, is that the 2nd fuse box?
    Mark
    vs commodore
    Oct 2009
    Tamworth NSW
    The trim panel under the steering column,you undo 3 clips or screws and it folds down,the fuses are behind that.
    VT series 2
    Dec 2009
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    I said the ECU was on the passanger. Forgot to mention that the clips and panel are on the drivers side... Sorry.
    My Commy
    Discuss.
  1. blinkers problem
    By mhoff25 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2009, 09:12 PM
  2. vr blinkers
    By stumpy03 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2009, 08:12 PM
  3. vr no blinkers
    By stumpy03 in forum Electrical Wiring / Questions
    Last Post: 14-07-2009, 08:33 PM
  4. VZ ss blinkers for VY ss?
    By Burto89 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-05-2009, 09:05 AM
  5. No Airbag Or Blinkers
    By shigan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2004, 02:26 PM
