Results 1 to 5 of 5
Thread: Parking lights and brake lights
    vr calais
    Aug 2009
    Default Parking lights and brake lights
    Hey all, I have a problem I tried searching but coudnt find the answer, I have just bought a 1993 vr calais and the parking lights come on when you put your foot on the brake.
    Also when you put the lights onto low beam the left front light wont go to low beam from parking lights the globes fine as i just changed it but no luck, anyone know the answers to these problems?
    cheers Daniel
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    Someone's screwed with your light circuits... You're gonna have to trace some circuits. Remove fuses and relays, eventually you'll isolate the problem.
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    check your brake/tail globes. should be double contact, twin filament globes. if single filament globes are used, it will create a short between brake and tail lights and your tail lights willl come on when you hit the brake, and brake lights will light up with tail lights.
    vr calais
    Aug 2009
    was the brake light causing the issues, still no luck with the left headlight not going to low beam.
    cheers Daniel
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    for the headlight, take the globe out and turn the switch on and check if you have 12V at the low beam terminal - probably a broken or loose wire
  1. How do I change my parking lights?
    By dynamik in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2010, 02:01 PM
  2. Electrical Gremlins- Brake Lights And Head Lights
    By xxNoblexx in forum Electrical Wiring / Questions
    Last Post: 10-02-2009, 09:59 AM
  3. vp brake lights dont work when lights on
    By omaz78 in forum Electrical Wiring / Questions
    Last Post: 26-10-2008, 09:38 AM
  4. vs parking lights flickering
    By manual crazy in forum Electrical Wiring / Questions
    Last Post: 23-09-2008, 07:23 PM
  5. Both my tail lights and brake lights have stopped working.
    By stuballs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2008, 11:35 PM
