Results 1 to 22 of 22
Thread: camber kit with airbags
    Bagged vs caprice sII
    Sep 2007
    Newcastle
    Default camber kit with airbags
    Hey guys just wondering if a camber kit will fix my camber on my car it has airbags in the rear so if there jacked up will the camber kit make the tyres camber out at the top? and also is the kit set to 1 height so if you go lower then this point will it camber again?
    cheers Mitch
    valakis_vx's Avatar
    valakis_vx is offline The Juggernaught Bitch!
    VUII Maloo R8 M6
    Mar 2009
    Knoxfield, VIC
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    jack the car up..... if your driving around low enough for this to worry you you're a dick.....
    There is no such thing as stupid questions, Only stupid people.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by TrikkBen View Post
    You made my night, I havent laughed this much in forever!
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Quote Originally Posted by HoZy View Post
    Your Welcome
    A little common sense goes a long way in todays world...
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Ben is the man.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    Sep 2007
    Newcastle
    camber effects older cars even at stock height..........so i guess everyone with cars lowered below stock height are dicks so im presuming you think 80% if not more of people on this site are dicks? my car at stock height has camber, i just want to save some rear tyres...........
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    im curious to know:
    When you lower a car with IRS you need a camber kit to correct the angle of tires with respect to ride height.
    If you raised the car again, the camber kit would now cause issues because of the camber angle and new height not matching?
    With airbags, if you raise it up and down, will a camber kit work at all heights? Is there a height it must be at for 90% of the time driving?
    Can you get variable rate camber kits?
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Sep 2007
    Newcastle
    Quote Originally Posted by azkwazere View Post
    im curious to know:
    aZk.
    exactly what i would like to know.
    cheers
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    camber kits only work at a specific point, u have a set height, adjust camber/toe then ur good to go at that height, soon as you adjust the height lower or higher, u move it from the adjusted hieght.
    with most camber kits, some of them move by them selves, and thats on lowered spring cars, mine move out of alignment after 6months, so imagine the bags lowering and raising it will throw it out rather quickly
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    A camber kit allows for adjustment. The camber can be set to the correct angle at a given ride height. Once the height has been changed, the camber will need to be reset to suit the new ride height.
    Camber kits a adjustable, they have an offset hole in the pin through the bush. As you turn the adjuster bolt, it moves the bush in and out in relation to the fixed point on the car. This changes the camber.
    You can't have dynamic or automatic camber adjustment. You will need to set you ride height that you drive most at and adjust the camber to suit.
    Visit my Facebook page
    Sep 2007
    Newcastle
    alrighty thanks for the answers fellers mite just suck it up and get one, wat would use recomend 2 or 4 point?
    cheers
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    go 4 point, which is just 2x 2point kit. it'll give you both camber and toe instead of camber or toe. best thing i've done to my car, my mates have gone the 2point kit then a few months later installed another 2point to turn it to a 4point kit they just didnt have enough adjustment.
    Sep 2007
    Newcastle
  15. #15
    pjdm1980's Avatar
    pjdm1980 is online now The Holden Hunter!
    Feb 2009
    Geelong, Victoria
    Who's the dick!
  16. #16
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Quote Originally Posted by Da_rooster1980 View Post
    Who's the dick!
    You?
    With a name like Da_rooster it really doesn't suprise me.
  17. #17
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    dont see a point of a camber kit on a bagged commo or any car infact. if u set up ur camber kit and then next time u drive it u raise and lower ur car with the bags its goin 2 stuff up the camber you have just set and u will have to set it up again in a few weeks or months, correct me if im wrong but thats how i see it
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
  18. #18
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    You?
    Nobody knows everything and he has a right to ask a question without you taking the piss, so if you've only got stupid shit to say then keep it to yourself!
  19. #19
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Who's the dick!
    Practice what you preech my friend.
  20. #20
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by Troy5L View Post
    The bag set up should have a pressure gauge, at the desired ride height that it is driven at it will have a certain amount of pressure in the bags, as long as the camber is set to the correct angle at that pressure (or height) it will be fine. The bags just have to be at the same height that the camber was set when driving to reduce rear tyre wear and excessive negative camber.
  21. #21
    Sep 2007
    Newcastle
    Quote Originally Posted by Not_An_Abba_Fan View Post
    cheers for that mate, just gonna bight the bullet and get one put in at what height/pressure i drive the car most at to try to see if i can rid of some camber
    and no offence trikk but reading your thread sounds like you drive with your car slammed aswell sometimes.........whos the dick now
  22. #22
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Quote Originally Posted by mking View Post
    I do drive it slammed, I'm not having a cry about camber though am I?
  1. Airbags!
    By daniel555 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-05-2009, 11:21 AM
  2. vy airbags
    By wallyvy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-05-2009, 03:49 PM
  3. used airbags
    By Zuicider in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2009, 01:35 PM
  4. Airbags for VZ
    By Brittennn in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-02-2009, 01:41 PM
  5. Airbags?
    By VXIIwagdf in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-02-2006, 08:23 PM
