Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VR - VS Holden Commodore (1993 - 1997)
VR - VS Holden Commodore (1993 - 1997) Talk about anything relating to the VR - VS Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 28-06-2005, 11:34 PM
Ride: N/A
audiosoup Executive
Default Vr flat battery, overheating help
hello
I recently started getting flat batteries. I checked out the old battery.. it was a bit ratty so I decided to buy a new one. Once it was installed, I dunno whether this is normal but the first two times when i went to go in reverse it stalled which it neva does.. i thightend the cables and it worked fine after that.. but then i took it to melbourne.. about 40 minutes into the trip that car was overheating and pushing past the H on the thermometer, i was in heavy traffic so i couldnt pull over. Though I put the car into park for about 30 seconds.. and after that it went down. On the way back it was fine and hardly came off Cold... any ideas why its doing this? I have checked the belts and water in the radiator. IT may be the crank angle sensor? IF it is, is it still safe to drive the car when it goes that hot?
thanks for any help guys
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 29-06-2005, 08:53 AM
Ride: VR Calais
Trade Rating: (0)
Ash81x Executive
could be air in the head?? my vr used to go way past the H when it got some air in there, undid the breather until the coolant came out and shes all sweet now
  #3
Old 29-06-2005, 11:39 AM
Ride: N/A
audiosoup Executive
oh ok.. il have a look at that thanks... today i started the car .. and it took a bit for it to start and when it did .. it had a rough idle for a bout 5 seoncds till it built it up.. which it doesnt usually do?? arg lol
  #4
Old 30-06-2005, 04:11 AM
Ride: 1996 VS Statesman Series 1 V6
Trade Rating: (0)
statesman_vs_s1 Executive
Has it only been doing all these weird and wonderful things since you replaced the battery?
Perhaps dis-connect the battery and remove, clean both terminals for the battery and check your earth straps etc. replace the battery and make sure your terminals are secure.
Could possible be a crook connection somewhere causing electrical errors with the voltage drop.
Only a guess but anything is worth a try.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Totally Flat Battery, Cant get into car Everton VY Holden Commodore (2002 - 2004) 4 08-05-2007 07:20 PM
VN battery going flat whats going on? Gazza2005au VN - VP Holden Commodore (1988 - 1993) 9 09-06-2006 09:59 PM
VS-Battery keeps going flat evanthe mac Electrical Wiring / Questions 4 29-09-2005 08:14 PM
VQ Battery Going Flat VQ Stato Electrical Wiring / Questions 11 11-07-2005 03:29 PM
Flat Battery Randy18 VN - VP Holden Commodore (1988 - 1993) 11 29-03-2005 11:38 AM
Mortgage Loans | Loans | Credit Card Consolidation | Debt Consolidation | Job Listing | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
