Results 1 to 17 of 17
Thread: Front sway bar link bushes
    Rumbl's Avatar
    Rumbl is offline = ShAkE AnD bAkE =
    VR V6 berlina-VS ss
    Jan 2005
    campbelltown nsw
    Default Front sway bar link bushes
    hey i wanna change my front sway bar link bushes on my vr the ones on there are gone
    just wondering if i have to take the sway bar off to change the bottom ones at all?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    just drop the 2 brackets that hold it up, and then do one side at a time. You'll have to put it upon ramps to get under there. Its not real hard at all to do them, i put in those z type ones with the polly bushes, i didnt really notice much of a difference but it stopped the clunk i had.
    Reaper
    Rumbl's Avatar
    VR V6 berlina-VS ss
    Jan 2005
    campbelltown nsw
    VR Executive
    May 2009
    its alot easy if you do you have to hold the actuall link with 13 or 14 mm spanner cant rember exactly and undo the nuts then change the bushes it would be awkwid with the wheel on i think...
    VP Exec
    Jun 2005
    You might also like to read the "How To" I wrote on changing the link rubbers - VR/VS aren't very different to VN/VP.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    would be better off with a shifter on the flat on the link rod and a 14 spanner on the nut. Its only difficult if your car is not level when you do it cos there will be tension in the bar.
    VrWagz1's Avatar
    May 2008
    wollongong
    i did it with the wheels on, i didnt see alot of benifit in having it off. It would have taken me longer to take the wheels off then to just hook in and work with it.
    Reaper
    Rumbl's Avatar
    VR V6 berlina-VS ss
    Jan 2005
    campbelltown nsw
    i thought you had to jack the whole front end up cause if its on ramps wont the sway bar have pressure on it? or i could be wrong
    Jun 2005
    Quote Originally Posted by Rumbl View Post
    thats the point really. you dont tighten them up to much
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    14mm ratchet spanner comes in handy for this job
    Power is measured in DECIBEL
    greenacc's Avatar
    VE Berlina
    Jul 2008
    The sway bar will only have pressure on it if you put it on one ramp or jack up one side. If you drive it up ramps it will be level so there wont be any pressure on it.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    i jacked up the whole front, cracked wheels off and did it without loosening the sway bar
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    remember to check them in a week or so..... (the nuts) if you dont do them up tight enough... well you know the rest
    VP Exec
    Jun 2005
    Quote Originally Posted by sweefu View Post
    You can certainly do it that way but it is virtually impossible to get the new rubbers to sit properly in the cups on the end of the anti-roll bar; they get squashed out of position because of the angle between the 'bar and the links. They end up being halfway to failure before you put the car back on the ground. That is why, with the wheels off and suspension drooped, it is better to drop the two brackets off the front of the 'bar so that it becomes possible to tighten the link bushes in place with the 'bar level and the links vertical relative to the 'bar.
    The transfer of weight off the front end with the car on ramps is probably not going to be enough to greatly affect the angle of the links, so yes, changing them with the front wheels on ramps should be OK. (A four post hoist would be even better.)
  15. #15
    VrWagz1's Avatar
    May 2008
    wollongong
    again ramps are fine, i did mine on ramps with the wheels on. Its no different to any other vr/s and there was no problems
    Reaper
  16. #16
    VX SS 5.7 man.
    May 2009
    Is there an easy way to replace the front sway bar on a VX witrhout removing the whole front meember??
  17. #17
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by whits86 View Post
    6 bolts, 2 in each bracket holding the sway bar, and then the one in each of the sway bar ball joint/linkage.
    Wrong section though, might be better asking a question in the VX section, although its not much more than above, you most certainly don't need to remove the crossmember.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
  1. Replacing Rear Sway Bar Link Bushes.
    By Ozzie in forum General
    Last Post: 23-07-2009, 09:20 PM
  2. Sway bar link bushes?
    By jimbojones889 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2009, 07:02 PM
  3. front sway bar bushes
    By mrhotdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2008, 03:58 PM
  4. "Front Link Bushes"
    By m3taL in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2008, 10:11 PM
  5. front sway bar link kit. VR
    By Hakka in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2006, 05:41 PM
