Results 1 to 10 of 10
Thread: how to remove auto selector to change bulbs
    vx berlina
    Aug 2005
    gladstone
    Default how to remove auto selector to change bulbs
    hi guys ive got the top of my gear selector off as shown in the pic but how do i remove the slide bit i have to get into the bulbs for my gear selector there blown cheers muz
    Attached Thumbnails Attached Thumbnails how to remove auto selector to change bulbs-picture-015.jpg
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    Yeah, you didn't need to do that. Pull the ash tray out (The thing you have full of coins in that pic). Then pull the hand brake up, put the auto shifter back to three, reach into the hole from the ash tray and pull the surround up. Doesn't take much force. Disconnect the cigarette lighter and it's globe, lift the black plastic "P,R,N,D,1,2,3" thing up... Your globe is under there.
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
    vx berlina
    Aug 2005
    gladstone
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Quote Originally Posted by muzza View Post
    What on EARTH have you done
    All you need to do to get to the bulb, is remove the black garnish (it pulls out), and unplug the cigarette lighter wires (should be two plugs). Then move it around the whole gear selector. It fits. Then the black slider bit can be forced off, and the light should be easily accesible like that. If not, the white housing around the shift light can be removed with four phillips head screws.
    I have no idea what you've just done, but it sure looks like hard work
    The 1972 HQ Kingswood
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    O_O I didnt even know that knob came off. That would have been an effort.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Fonzie's Avatar
    300zx 2+2 Targa
    Aug 2008
    Quote Originally Posted by Vee-ard View Post
    That's what i was thinking too. Hope he can put it back on...
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    VS Berlina 3.8
    Dec 2008
    This tells you how to remove the garnish -
    Stereo Install/Removal (VN - VS)
    Tell us how hard it was to pull it apart and put it back together.
  1. VE Auto Selector Change
    By sfor in forum VE Holden Commodore (2006 - ?)
    Last Post: 24-09-2011, 05:51 PM
  2. How to replace auto gear selector.
    By mobster in forum VE Holden Commodore (2006 - ?)
    Last Post: 02-05-2009, 05:56 PM
  3. VT Selector Cover (auto)
    By KingNothing in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2009, 07:38 PM
  4. VN-VS - Change gear selector LED
    By Infus10n in forum Holden Commodore How-To's
    Last Post: 29-11-2008, 12:05 PM
  5. Bulbs in Gear Selector Blown
    By dave0103 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-11-2006, 10:42 AM
