Results 1 to 12 of 12
Thread: Hot Engine Beeps on L3 upgrades
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default Hot Engine Beeps on L3 upgrades
    I have an issue with some VR/VS Lever 3 upgrades.
    The hot engine beep code is chiming away. If I plug in a cluster I get this chime too. I have the orange white and pink black (via a switch) to positive and the 2 black white and grey wires to negative, to test the clusters with. Most of the 4th plugs cut from VR/VS looms dont have the extra green wire as the VN/VP units have.
    Hot engine =
    T1 pause (1)
    T2 pause (1)
    T3 pause (1) T3 pause (1) T3 pause (1) T3 pause (1)
    T1 = 2560 Hz 1/8 sec
    T2 = 3200 Hz 1/8 sec
    T3 = 4266 Hz 1/8 sec
    T4 = 6400 Hz 1/8 sec
    Pause = 1/8 sec
    My question is where would the cluster be getting this error code from - what would be making it go off? There is no wire for it in the L3 looms 4th plug.
    I've looked over the "tripin" thread for a clue - but nothing....
    and 3 Dangerous non ABS VN's
    VX Calais
    Jun 2008
    SA
    mine did that when i retrofitted the level 3 into my Exec....until i discovered that i didnt connect the temp wire properly. once i joined that wire properly, the temp chime hasnt made a noise since.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Ive done a couple of vn/ps and used a that no 4 plug cut from a l3 equiped car and simply never connected the extra wire in that top row....never had a issue....the temp input wire to the trip computer is actually on the second row of the no 4 connector in term 12 and should be connected to the green wire on inst conn 3 term 3 of a vr/s dash loom.That wire runs back to the sender unit on the engine....it should read 280ish ohms cold ....70 to 80 mid ....and 40 ohm hot....so the lower the resistance to a short the more chance it has of triggering the chime/light and it will rechime every 60 seconds until you turn the ignition off
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by markovr View Post
    Just double checked my template loom used to make the VR/VS patch looms and my green wire C4#12 goes to C3#3. I test each loom via multi-meter before fitting.
    The warning lamp does not go off (flash) - just the warning chime. And the chime only sounds when the car moves off - Can sit and idle for ages - but will only sound once driving.
    Nov 2003
    northside brisbane
    sounds like the handbrake warning chime as it works if you drive off with the handbrake on not the hot engine maybe.
    88GreenVN's Avatar
    Jun 2006
    And then I look at this ...
    Hot engine C = T1 pause (1) T2 pause (1) T3 pause (1) T3 pause (1) T3 pause (1) T3 pause (1)
    Park brake C = T1 pause (1) T2 pause (1) T3 no pause T3 pause (1) T3 pause (1) T3 pause (1)
    So yep look like the handbrake. I just missed the no pause bit.... Now to work out what is wrong with the handbrake for it to chime.
    88GreenVN's Avatar
    Jun 2006
    Just spent some time looking at the handbrake wiring for the VP and Exec VS and cannot find an issue with it.
    The VR/VS has the handbrake chime going off when the car is 12kph for more that 2 seconds and volts are zero (hand brake on)
    So some how the L3 cluster has a zero volts reading on the hand brake circuit. Now to find it.....
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by 88GreenVN View Post
    Found it! - The first pin on the voltage regulator in the cluster was cracked. Re soldered and chime stopped.
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    Now this sounds very much like the problem I have.
    Wired and fitted the cluster 2 days ago.
    All gauges working and digital side of things lighting up as they should.
    Went for a drive and the chime sounded at about 10- 15 klm's h. It only went off once while I drove around the block and back home.
    Today I fitted the other part with the buttons (trip control panel)
    Also ran the yellow black wire over to the passenger side ecu connector.
    Bingo... now the other digital dash displays have meaningful readings and the mode/+/- etc all work.
    Went for a drive to check things out and the chime now sounds about every minute or two.
    Only does it when you are driving... not parked or idling.
    Have not tried pulling the handbrake to see what happens over 5 klm/h.
    Maybe this cluster also has the dreaded dry joint on the voltage regulator.
    Where about is the voltage reg located?
    Is it a case of dismantling the whole cluster to get at it?
    Presumably it is inside on a pcb with a heatsink attached to it?
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Paul13pp View Post
    Lightly pulling the hand brake on with button in will give you the chime. And yes lens off and speedo/tacho out to access the voltage regulator. The first pins crack where the ribbon tag plugs in. Give every joint a fresh lick of solder too while your at it.
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    Cool, will do, and I found your other thread about it with a picture of the PCB.
    Just another question...
    My son has a VR and he changed the engine and box for a VS one the other week.
    Along with this they also changed the ECU so the VS motor would run and put some wiring in from the Calais that the engine came out of connecting the ECU and also allowed the gearbox connector to fit. (VR gearbox had a different plug)
    Son also got the L3 dash from this VS Calais and plugged it in but no digital display comes up at all.
    When I plugged my L3 cluster in to my VS exec, without hooking any other mod wires up, the digital display for the odo read ok... his does not.
    Is the body control module different and does that thing have any relation to the dash cluster whether L2 or L3 or rather VR/VS?
    He still has the VR BCM installed and his VR has power windows if that helps any.
    His original L2 speedo is not working and he has changed the sensor that feeds signal to it with no result.
    Apparently sometimes it works, but not often.
    He has tried several different clusters as well.
    Might be a break or bad connection in the wiring somewhere.
    88GreenVN's Avatar
    Jun 2006
    The Calais BCM is different for sure. The cluster, if not showing ODO is not getting 12v from the orange wire (black white to earth) or the LCD screen has got a problem or put in upside down. Run the cluster in Diag mode to see if you can get the segments to light up.
    Check continuity between the speed sensor and the purple white wire in the dash @ C2#2. That is if the cluster has a good PCB on the back - look up the speed signal tracks and follow with pen to see if it has any broken bits.
    If several clusters give funny speedo readings it's the wire or dodgy speed sendsor (second hand units can be dead also) The L3 cluster gauges shuld work fine without a patch loom installed.
  1. VS Warning Beeps
    By DocBald in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2009, 11:41 PM
  2. Engine Upgrades
    By 85_VK_EFI in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-01-2007, 09:40 AM
  3. Engine k/w upgrades....
    By Australian&Antichrist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2005, 03:14 PM
  4. inside engine upgrades help
    By Transmit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-08-2005, 07:56 PM
  5. It Beeps At Me?
    By Robbie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2004, 12:06 PM
