Results 1 to 12 of 12
Thread: l67 statesman
    Vs Statesman III
    Mar 2009
    Default l67 statesman
    sounds like a metalicy sound coming from the supercharger any ideas on what it could be thanks
    VT spac super6
    Nov 2008
    Riverton sa
    how long has it been doing it?
    any noticable changes in performance?
    rattling sound can be cause by either worn bearings causing the rotors to hit, my old charger did this
    or in the snout theres a coupler that connects the snout to the rotor gears that could be worn giving the knocking sounds
    Vs Statesman III
    Mar 2009
    i think it could be both does it cost much to replace these items ?? cuz its kinda like a knocking and grinding sound
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    could be the rotors have worn on the end plates are are shreading metal thru ur engine
    u'll need to feed us a little more info mate, when did it start happening, is it constant, do u do regular servicing, have you changed the oil in the charger? any other info on how the car is performing would be good too.
    VT spac super6
    Nov 2008
    Riverton sa
    how manys ks has it done? any mods ie smaller pulley etc
    if you take the belt off running the charger, rock the pully back and forth and check for slop, if theres play moneys on the coupler
    from memory theyre about 30bucks whether you replace it yourself or not depends how confident you are.. its a pretty straight forward and easy job to do
    if its the bearings theres a chance the rotors have lost their coating aswell then your better of replacing the charger completely
    the bearings arnt a 5 minute job you need someone with a press and the knowhow
    Vs Statesman III
    Mar 2009
    yea its pretty constant its been doing it since i bought it a couple of months ago i regualary service it its done 238,000 havent checked the supercharger oil
    Vs Statesman III
    Mar 2009
    i actually did try that took the belt off its got like a bit of slack when i turn the charger snout left not sure if its supposed to do that
    VT spac super6
    Nov 2008
    Riverton sa
    try giving it a few quick revs and see if it quietens it aswell, with the front bearings gone in myne it would settle with a rev but at a constant speed get louder
    Vs Statesman III
    Mar 2009
    VT spac super6
    Nov 2008
    Riverton sa
    Quote Originally Posted by crazstaat View Post
    in that case its most likely the coupler.. i got 270thousand ksm out of the original bearing in the first charger
    The black round piece is the coupler as you can see there is 6 holes in it, 3 holes take by the dowels on the snout shaft
    and this is where it goes onto the charger
    Vs Statesman III
    Mar 2009
    ok sweet as hope its that well would i have to replace them gaskets too were would i get them from and as for the oil how much do i know to fill ?
    VT spac super6
    Nov 2008
    Riverton sa
    iv never used a gasket and its been apart alot
    Iv only ever used a good sensor safe gasket glue
    i cant remember the amount of oil but the bottles you buy hold the exactly amount from memory not much oil at all
    while youve got the snout off you should pull the rotors out just to inspect them
    if it looks like this, its bearings causing the rotors to "knock" together
  1. vq statesman with vs statesman front
    By Mazzone_Child in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2012, 02:39 PM
  2. Got Given VQ statesman.
    By mattsvqv8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-02-2009, 05:16 PM
  3. vs statesman reo bar $?
    By jerzey1234555 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2006, 01:50 PM
  4. VS Statesman
    By VLishes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2005, 09:11 AM
