Results 1 to 15 of 15
Thread: Senator probs again...
    VS Senator 215i
    Aug 2005
    WA
    Default Senator probs again...
    Got another problem with my Senator. Seems to be never ending at the moment. Got a flatspot up to 2000rpm. It feels like its starving for fuel and then away it goes. I've changed plugs, fuelfilter, had the Carbonkleen done and even put some additive in the tank. Been in the shop twice and still the same. Apparently the harmonic ballancer has moved on the rubber, so the timing is set close by the mechanic, seems pretty good anyhow. This seems more common when the car is cold but comes and goes when its warm. Any ideas where to look next?
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    IF the harmonic balancer has moved i'd be replacing it, before it moves through your bonnet....
    Any error codes ? New mechanic perhaps ?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    if you have done all that then it sounds like it could be your dizzy. Try replacing the cap and the leads first, then the whole thing.
    Reaper
    VS Senator 215i
    Aug 2005
    WA
    I havn't checked for any error codes, the paper clip thing seems a bit dodgy, prob isn't just sounds a bit like a farmers fix. I will be replacing the harmonic balancer then look at the cap and leads. What can go wrong inside the dizzy?
    greenacc's Avatar
    VE Berlina
    Jul 2008
    If the metal electrodes inside the dizzy cap have lots of white ash on them, looks kind a like a hot spot.. this can reduce the power of the spark getting to the plugs. Same on the rotor button itself. The backyard fix is to scrape it off, or just buy a new cap.
    Oh, and the paper clip trick is a Godsend, brilliant cencept actually. All it does is make a light on your dash flash, there's not much to it.
    VS Senator 215i
    Aug 2005
    WA
    Will look in the dizzy early next week, working days all weekend. Then I might chuck a clip in and see what pops up. Cheers
    VrWagz1's Avatar
    May 2008
    wollongong
    dizzy has you hall effects sensor inside aswell as you hv stuff so there is plenty to go wrong in it.
    Reaper
    VS Senator 215i
    Aug 2005
    WA
    Thanks for the replys fellas. Still havn't had a chance to look into whats wrong with this car. Seems to run well if you just get the revs past 2k quick smart.. can be interesting whith the wet weather were having.
    Anyhow the cars in the Panel shop at the mo some bastard tried to force open the drivers window, scratched the tint and put a coin down the drivers side when they couldn't get in. Ain't it funny what some people do for kicks?
    VS Senator 215i
    Aug 2005
    WA
    Chucked the paper clip in this morning and got a 12 and a 31. I don't think its a sensor problem. I am gunna rip the dizzy cap off when the motors cooled down and put some new leads on. Getting closer to fixing this i reckon.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    VS Senator 215i
    Aug 2005
    WA
    Something about the alarm. I would have to have another look at the list.
    VS Senator 215i
    Aug 2005
    WA
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    I think you must have read the code incorrectly. If you had a 31 you would not have been able to start your car at all.
    VrWagz1's Avatar
    May 2008
    wollongong
    is that a v8 code or v6 code, cause im sure they are different, either way that dosnt sound right. Like above if its theft deterent then the car wont start at all or if it some how lost it while driving then it would just stall dead.
    Reaper
  15. #15
    VS Senator 215i
    Aug 2005
    WA
    Just Commodores - For All Your Holden Commodore Needs
    This is where I got my code descriptions from. Car starts and runs Ok. Just not as smooth as it should. I may disconnect the battery for a while and try again to see if its an old code, otherwise
  1. VS Senator V8 Idle Probs - Duel Fuel
    By deserthead in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2008, 05:58 PM
  2. VX Probs
    By coolvxss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-12-2006, 09:35 PM
  3. VL Probs
    By Marky in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-11-2005, 04:17 PM
  4. VS probs
    By VScom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2005, 09:57 PM
  5. vk a/c probs
    By dave_17 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2005, 11:24 AM
