Results 1 to 17 of 17
Thread: Vr V8 Temperature
    vr ute
    Mar 2009
    Default Vr V8 Temperature
    I not long bought a Vr ute and when i got it it was running cold, i changed the thermostat and now it runs at the second big mark.
    is this normal??
    cheers
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    thats a bit high for my liking, especially in this cooler weather. Try taking the thermostat out to see if it fixs it. If so get yourself a new one again.
    Reaper
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Flush your system, go get yourself a nice 82c Thermostat ^_^
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    vr ute
    Mar 2009
    the system had been flushed about 10000kms ago.
    that was sitting idling after a bit of a drive, it was moving between the line its on and the next colder one down.
    i'm pretty sure it was a 82c one
    where should it read??
    vr ute
    Mar 2009
    i just checked the box it came in, its a 91c one. according to the box it's the correct one
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Original is 88c, I run a 82c so do a lot of other people...
    vr ute
    Mar 2009
    sweet as. sounds like its the proper one then. i dont drive in traffic often so it'll be all good.
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Why do you want a 91c Thermostat? I just said original is 88c & most people run 82c on a 5litre when they change it.
    vr ute
    Mar 2009
    it only 3c above stock so i dont think that much will matter.
    i done a bit of looking on other forums and found that they should run between 85 and 95c
    VP Executive R-spec
    Jan 2005
    I run a 82c thermostat but will be running a much hotter one once I get rid of the banana manifold. The extra sludge factor in the motor isn't worth the few extra horses
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    by that picture and u said sitting idling after a drive seems perfectly fine. it aint gonna move much further down unless u drive around getting the cool air in. thermo fan usually kicks in around half way so it dont seem like u have a problem. for ur own sake get a flush done anyway, midas do them for around $88 including thermo, gasket, high pressure blast and holden coolant. well worth it to get rid of the gunk
    Mar 2009
    and if it was running cold all the time, couldve been that the thermo that was in there was stuck open, making the water run through all the time
    vr ute
    Mar 2009
    yeah it was stuck open a 1/4 inch.
    i spoke to a mate who has the same car and his runs at the same temp. so i'm happy with that.
    Mar 2009
    all good then...at least it wasnt like mine when i first got it...rusted closed :P
  15. #15
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Sounds like your engine fan may not be working properly if the temperature gets that high on a cold day when idling. To test:
    1. Drive vehicle to achieve normal operating temperature.
    2. Stop vehicle and run engine at approx 2000 rpm.
    3. Listen for fan engaging (indicated by fan noise or "roar) when engine is hot. When temperature has been reduced sufficiently, fan clutch should disengage - indicated by a drop in fan noise.
    4. If fan is continuously engaged or disengaged, replace thermostatic clutch.
    BTW, Holden service manual says that thermostat should begin to open at 89-93C and be fully open at not more than 103C.
  16. #16
    vr ute
    Mar 2009
    it wasnt a cold day.
    i've done that test fan sounds like its working fine.
    i'll check the temp with a marked gauge when i get a chance
  17. #17
    Bilbs's Avatar
    Bilbs is offline Donating Member
    VR 5.0 M5 Ute
    Apr 2007
    Churchill
    that looks about right, just cant remember exactly what my lev 2 dash was, but if you take it to a workshop with a scantool, they can plug in an tell you what temp its at, and yeah, 91 deg is a good t/stat, dont want the motor too cold, motors make most power up round 90 - 95
  1. VS Temperature
    By Acclaim96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2009, 02:51 PM
  2. VT Temperature
    By 05LVQ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-10-2007, 10:37 PM
  3. What temperature is right?
    By wetwork65 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-01-2007, 12:22 PM
  4. Temperature
    By paullmichelle in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2005, 07:54 PM
  5. Temperature
    By Flash_VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2005, 06:40 PM
