Results 1 to 20 of 20
Thread: commodore problem
    vs-vl
    Aug 2009
    Default commodore problem
    Hi there, i currently have a vs commodore with a problem as listed,
    20minutes to the dot it will stop, sometimes restart straight up, sometimes affter a little while,
    after it starts it will run fine. even in a 900kay trip. as soon as you let it sit for 4-5 hours. the same problem will arise agian, then after the stall, its fine agian,,
    had it to holden and various places and on computers and no one can seem to fix it,
    replaced, crankangle sensor,fuelpump,coolant temp switch, dfi module, and now the computer....
    any idears?
    Cheers,
    Ice,
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    All that pops into my head would be the alternator maybe. I'll wait for some other ideas. Sounds like everyone else you've taken to is having some trouble with it too aye. Maybe time try another mechanic.
    vs-vl
    Aug 2009
    been to 3, including holden, and im a marine mechanic and have backed there work up with all the tests of my own...
    alternator and batterey have also been replaced... ive treid another loom to, to no avail,
    car is really starting to cost money,.... not to mention getting close to being burned!!!
    93vp 3.8
    Aug 2009
    The Blues Mobile
    Dec 2008
    Western Sydney
    That's unlucky. When you say it does not start do you mean you just keep cranking it over but there is no go, or kinda starts and then dies?
    The Blues Mobile
    Dec 2008
    Western Sydney
    Quote Originally Posted by superslave View Post
    how do i start a thread or post on this site
    You just posted... Also top left hand corner you'll see a button that says "New thread" if i'm not mistaken
    vs-vl
    Aug 2009
    cranks, and usally starts straight up, although sometimes it dies a few times after being started agian,, say 30 sec of running then drops out,
    93vp 3.8
    Aug 2009
    Unhappy Help please! how do i replace fuel sender
    Can someone please give me step by step instructions to replace fuel sender in a 1993 vp berlina. i cant afford an auto electrition and i have replaced gauges and that didnt help. i think my fuel pump is with my sender so not sure if i will do any damage taking it out and having a look when i have never done it before. thannks
    93vp 3.8
    Aug 2009
    The Blues Mobile
    Dec 2008
    Western Sydney
    Hmmm, i'm out of ideas already (not like i had lots to start with ) I'll ask my mate and see what he says.
    vs-vl
    Aug 2009
    VX Calais
    Jun 2008
    SA
    anti-theft system maybe? how old are the key heads?? problem with the BCM??
    vs-vl
    Aug 2009
    No anti theft system fitted. and ive ruled the key heads out as its excatly the same time every morning,
    whats a BCM?
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Quote Originally Posted by iceknight View Post
    whats a BCM?
    Body Control Module. It's located behind the fuse panel. It controls things like power windows, variable wipers, cruise control etc. There are three types Low, Mid and High.
  15. #15
    Holden VS Executive Sedan
    Apr 2009
    Blacktown
    how are the injectors in the car, how are spark plugs, how is the fuel pump or filter, how are the coil packs, hows the butterfly in the throttlebody, and you say that they have gone over your computer, and you have replaced it right, does the engine light come on at any point and lastly does the engine run rough (like vibrating and stuff badly)
    Tit-Tit-Titian™
  16. #16
    vs-vl
    Aug 2009
    new pump. filter, injectors have been done, new sparkys, new coil packs/dfi, no engine light, and stops like a heart beat, no coughing spluttering or anything,
    definatly electrical somewhere. im sure
  17. #17
    Apr 2009
    Blacktown
    wat about the fuel pressure regulator
    Tit-Tit-Titian™
  18. #18
    vs-vl
    Aug 2009
    Id be guessing if it was a fuel pump regulator it wouldent stop EXACTLY the same time every morning. then after a restart its totally fine,.. but i could be wrong,
  19. #19
    vs-vl
    Aug 2009
    Is it a possibilty it was the ECU shooting down the crank angle sensor every time i replaced it?????
    maybe i should replace both these items at excatly the same time???????
  20. #20
    Apr 2009
    Blacktown
    well if you replaced the computer, shouldnt do it anymore, could be wiring shorting out and earth to the shazzey
    Tit-Tit-Titian™
  1. Vs commodore computer problem!!!!!! Help!!!!!!!!!!!!!!!!!!!!!!!!!
    By glen3.8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2009, 06:09 AM
  2. VP Commodore Starting Problem
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2006, 02:19 AM
  3. Vs commodore idle problem
    By lexcedore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2005, 01:05 PM
  4. Idling problem, VL commodore, 88
    By Commo1 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-02-2005, 02:12 PM
  5. Vh Commodore- Fan Problem Plz help
    By pinguino in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-04-2004, 06:09 PM
