Results 1 to 5 of 5
Thread: removing the tube shape rear muffler on standard v6 exhaust
    vx berlina
    Aug 2005
    gladstone
    Exclamation removing the tube shape rear muffler on standard v6 exhaust
    guys does any1 no how much of a job the rear tube shape muffler on a standard vs v6 exhuast system does ?i was toying with the idea of removing it ,is it just another muffler or does it do another function as well ? cheers muz
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    It'll give you a bit more of a note down low, but if your exhaust has the flexi pipe you'll get a loud whistle out the exhaust at higher rpm, people will mistake your car for a low flying 747. If you're going to delete the rear muffler, you'd better delete that as well. All that aside, removing the rear muffler should have zero negative effect on the workings of everything else.
    Check out my VP right 'ere!
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    it will sound louder as the muffers do exactly that, muffle the sound. wont be a problem as camstatic said on any negative effects. it just might sounds shit, might!
    The main question is why are you toying with the idea of removing it? what are you trying to achive?
    camstatic's Avatar
    VP S1 V6 Executive
    May 2006
    Regional SA
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    The rear one is called a resinator, I`d thought I`d throw that in learning FTW.
  1. rear muffler vs front muffler
    By richardpalinkas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-05-2009, 10:22 PM
  2. w.t.b rear twin exhaust muffler vy melb
    By bluethunder_69 in forum Swap / Wanted to Buy / Trade
    Last Post: 08-04-2008, 07:27 PM
  3. Do all V6 VX Commodores have a massive exhaust up to the rear muffler?
    By DavidPartay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2006, 09:45 AM
  4. Muffler on standard exhaust
    By craigy09 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2006, 06:35 PM
  5. removing rear section of exhaust on VH
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-11-2005, 06:19 PM
