Results 1 to 18 of 18
Thread: Urgent help needed
    VS Vacationer
    Jun 2006
    Default Urgent help needed
    Help.
    I just went for a ride to the shops and something happened to my ignition.
    I now cannot turn my ignition off. Motor is still running in the drive as I type this. I don't have much juice and I am worried I may damage my car.
    Is there a quick way to turn the motor off?
    chrism182's Avatar
    chrism182 is offline VX S Pack
    VX S Pack M5
    Sep 2008
    Victoria, Australia
    If it's a manual you could always stall it. :P
    Otherwise I'm not real sure.
    eziautoparts.com.au
    Your total auto parts store on the web!
    VS Vacationer
    Jun 2006
    Swordsy's Avatar
    Swordsy is offline mmmm beer....
    VUII Maloo R8 - XJR1200 - XR450R
    Nov 2007
    Newi NSW
    Pull the main engine relay/fuse under the bonnet.
    Quote Originally Posted by STEALTHY™ View Post
    Public Service Announcement.
    Those members who do not hold a 'sense of humour' should not venture into the 'jokes/humour' section.
    VE Omega
    Aug 2009
    Canberra, ACT
    i dunno if d/c battery would do anything?
    maybe if you can reach the throttle wire in engine bay ( i dunno if these are exposed like they are on the VP) you could physically try and move it to lose position and see if it revs so low it stalls.
    i really have not explained that well, but i dunno if that would work.
    sorry i dont know more.
    VS Vacationer
    Jun 2006
    Thanks for the suggestion Swordsy, but I am not able to do this as I know nothing about things under the bonnet.
    Looks like I'll have to call the racv, big joining fee coming up. Damn.
    Oh well, at least I was able to lock it and pick up a slab while at the shops.
    Swordsy's Avatar
    Nov 2007
    Newi NSW
    Black box right behind the battery, remove the lid from the sides and it'll have a pic to show you what is what.
    Swordsy's Avatar
    Nov 2007
    Newi NSW
    Fuel pum p one will also do it, do that one
    commodore
    Aug 2009
    australia
    just dissconnect the battery it will stop the electric fuel pump no fuel no run
    VS Vacationer
    Jun 2006
    Awesome Swordsy. The fuel punp one did it. At least it has turned the motor of for now.
    racv wanted 300$ for a call out fee,\.
    Thanks very much.
    Swordsy's Avatar
    Nov 2007
    Newi NSW
    Quote Originally Posted by gnol View Post
    Thanks very much.
    No drama's, but now you need to find out why it didn't turn off with the key. that could be the tricky part.
    VS Vacationer
    Jun 2006
    Quote Originally Posted by Swordsy View Post
    It is like the whole bit where the key goes was loose and not responding at all. No matter which way I turned the key full on nothing would happen.
    I think I see a big bill coming up.
    edit: BTW I love your panel van. Is that a HQ with a hj? front end.
    I did a lot of kicking around in the 80's in a HQ panel van
    Swordsy's Avatar
    Nov 2007
    Newi NSW
    Have a poke around and see if you can find any loose electrical connectors near that fise box or under the steering wheel, it could be that simple. (hopefullly..)
    She's a full HZ, nearly the same body (slight differences) and the front end ran from hj - hz, just with a different grill. Got GTS Guards and a gts front to go on it tho
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    the pin retaining the ignition barrel could have gone walk about? or the ignition barrel is stuffed.
    you can get a full set from a wrecker for around $80 im told, and its not that hard to fit.
  15. #15
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    I had this with my VS, the shaft that goes into the ignition switch (from the barrel) snapped. Removed the fuel pump relay then disconnected the battery.
    Remove the barrel and the switch at the rear of the barrel, and remove the left over shaft from the switch. Replace the barrel, and all should be fine.
    If you leave the barrel in and remove the rotary switch at the end, you can start your car with a screwdriver (insert into rotary switch and turn). The key has to be in, and in the 'run' position, to bridge the contacts on your key etc.
  16. #16
    VS Vacationer
    Jun 2006
    Hey all,
    thanks for the help.
    I am not mechanically minded so I will not be able to do this. Being a one car family we really need to have the car working.
    I'm getting a mobile mechanic out this morning.
    Will cost a fortune but I really have no other option.
    cheers
    gnol
  17. #17
    vs v6
    Nov 2009
    i would advise NEVER to disconnect battery first as the the voltage from the alternator needs to go some where and if you disconnect battery its gonna most likely burn out your wiring!
  18. #18
    vs commodore
    Oct 2009
    Tamworth NSW
    Disconecting the battery with the engine running can overload the alternator and fry it.Dont do it.
  1. Urgent help needed!!
    By AirStrike in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2008, 11:20 PM
  2. urgent Help needed
    By overgrown in forum Car Audio
    Last Post: 11-06-2008, 07:47 PM
  3. Urgent Help Needed
    By Keeper85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2007, 08:32 AM
  4. urgent help needed
    By back_in_a_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2007, 05:42 PM
  5. urgent help needed
    By tomwallace in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2006, 01:12 PM
