Results 1 to 2 of 2
Thread: 5ltr torque converter flyin apart inside??
    VS v8 manual Calais, Ve ute, 68 Hk Holden v8
    Aug 2009
    coalville, vic
    Question 5ltr torque converter flyin apart inside??
    hey
    has anyone owning a 5ltr have/had problems with there std torque converter flying to bits internally or some other issue??????
    also i was looking at puttin at 2,200rpm stall and stage 2 shifty is that a good choice???
    paying $500 for the stall and $250 for the shifty is that a good price????
    thanks
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    never really heard of a converter flying to bits but stranger things have happened, 2200's not a bad stall for a stocky engine, standard is around 1800 so you'll get a bit more punch off the line without needing a cam, kits are good too but don't go overboard, the everyday drive becomes a ball breaker if you do a lot of suburban driving as it clunks up and down thru the gears. Remember that with a stall the box doesn't feel like its changing as hard as it. When they feel that hard, its usually from a standard stall when the revs drop between changes. A lot of people cant work out why 'it used to chirp between gears but wont now with a stall'. Price is good, could prob find a stall cheaper but if they are from the same guy, the kits a pretty cheap price, what brand stall is it.
  1. vr/vs torque converter
    By bigpig in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2008, 11:13 PM
  2. torque converter
    By kniever in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2008, 03:26 PM
  3. torque converter?
    By xcop5l in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-11-2006, 07:59 PM
  4. Torque converter?
    By spauldj308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-02-2006, 07:02 PM
  5. Torque Converter
    By Indy_387 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2005, 03:52 AM
