Results 1 to 11 of 11
Thread: vs problem
    whitey152's Avatar
    whitey152 is offline cruzen
    1996 vs berlina
    Jul 2008
    port macquarie
    Default vs problem
    Hey guys.
    Yet another thred on my car. lol
    Ok so here it goes
    my car runs pritty rough on idle
    and when i apply the brake and hold it on like at trafic lights it gets worse kind of shudders constantly and theres almost a knocking sound and i have no idea wtf is happning lol.
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Vacuum leak??
    You have a Berlina with climate control - do you have problems with the air flow moving from the centre vents to your feet under acceleration?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    when u say there is a knocking sound... does it sound like engine, suspension or exhaust, like metal on metal?
    pjdm1980's Avatar
    pjdm1980 is online now The Holden Hunter!
    Feb 2009
    Geelong, Victoria
    Definaty sound like a vaccum leak because brakes are vaccum assisted
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    So would the next move be to physically check all the vacume hoses and the also perform a check on the brake booster?
    I THINK and thats just an I think, not an I know, but to check the booster run the car for a few mins then turn it off.
    Press the brake pedal a few times, the pedal travel should get less and less and feel tighter and tighter, if that is the case then the booster is ok, I hope someone smarter can confirm this.
    whitey152's Avatar
    1996 vs berlina
    Jul 2008
    port macquarie
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by whitey152 View Post
    Hey guys.
    Ok so here it goes
    Is it auto and if it is,is it changing gears when it should ? starting to sound like the flex plate if your booster and vaccuum hoses check out.
    Holden VS Executive Sedan
    Apr 2009
    Blacktown
    does you car have abs, and if its running rough, could be a few thinks, most common is injectors need cleaning
    Tit-Tit-Titian™
    whitey152's Avatar
    1996 vs berlina
    Jul 2008
    port macquarie
    yeah its abs and when the cars in drive and its stoped say on a hill and im siting there with no brakes on it still does it so basicly under load at idel?
    Apr 2009
    Blacktown
    Sep 2005
    Flex plate...the knocking noise will be slightly audible when putting car from drive to neutral or park when about to switch ignition off. have you ever heard crook balance shaft bearings at all on the VN's ? does it sound like that ? if yes then id be getting under there with a screwdriver and use it as a listening device,place it onto the torque convertor flywheel housing and listsen through the handle of the screw driver if anything is a miss in that area it will be audible.
LinkBacks (?)
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  3. sub/amp problem
    By naf33n in forum Car Audio
    Last Post: 04-11-2007, 11:10 PM
  4. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  5. Oil Problem
    By zammits ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2005, 09:23 PM
